Fuzzy sound -- any ideas?
WarpedWoof
WarpedWoof Posts: 5
edited July 2012 in DIY, Mods & Tweaks
Hi! I'm looking for some ideas. I recently bought a pair of old Monitor 7A's with the Peerless tweeters. One mid driver was locked so I went ahead and got a pair of replacements from Polk, so I have new mid drivers on both speakers. I'm driving these with a Denon DRA-835 amp, but I've tried using another amp with similar results. Basically, not all the time, but a good amount of the time the sound is muffled, heavy on the low mids with recessed vocals. At first I thought this was a source problem, but it seems like this is not the case. The same source material can sound beautifully clear or poor. So far I've tried changing speaker placement, different cable and a different amp. Changing the placement did help somewhat, but didn't fix the problem altogether. Could this be due to crossover problems?
Any suggestions welcome!
  • drumminman
    drumminman Posts: 3,395
    edited July 2012
    Do you have output from your tweeter(s) when the sound is bad - I would check that first.
    Move onto the simple things - do you have good connections between speaker wire and binding posts?
    Also, if you have fuses I'd go ahead and replace them. Sometimes they can cause this sort of thing even if they appear to be good - and they're cheap.
    other possibilites include a cold/broken solder joint. You'll need to get inside the speakers and have a little knowledge of circuit boards/crossovers to check this. Visually inspect everything. If you know how to use a multimeter now is the time.
    Sometimes you can find cracks in joints that appear good if you slightly flex the circuit board under a strong light.
    Good luck and post what you find.
  • WarpedWoof
    WarpedWoof Posts: 5
    edited July 2012
    Great feedback! Much appreciated.
    I hadn't thought about the fuses. I have noticed that sometimes if I simply pick up a speaker and move it around then set it down, the sound improves! I will try the fuses first, then get out the multimeter and have a go at the crossover board.
    Thanks!
  • WarpedWoof
    WarpedWoof Posts: 5
    edited July 2012
    Changing the fuses made a huge difference -- I don't think the speakers have sounded this clear since I've had them. Thanks so much!
  • drumminman
    edited July 2012
    :cool:
  • skrol
    skrol Posts: 3,499
    edited July 2012
    You could have a bad connection internally. It could be a wire to the tweeter, a component on the crossover or even a cracked crossover printed circuit board. I found a bad solder joint on one of my crossovers and a joint that was not even soldered where two caps were paralleled. The lead of one was wrapped around the other but not soldered.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • WarpedWoof
    WarpedWoof Posts: 5
    edited July 2012
    Yeah, the joy has been short-lived -- fuzzy sound is back.
    I tested the resistors (there are two in my version of the M7 crossover) and one is out of spec. I tried to test the caps, but I guess I can't do that accurately without removing them, and if I'm going to go to that much trouble, I may as well upgrade them. Hopefully, any cracks in the PCB will be evident at that point :)
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited July 2012
    May be worth doing the xovers than.also ck the fuse holders, they can get loose over age as well as the contacts to them inside.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
