4 subs - ported box...which way should they face?
b_knockwood
b_knockwood Posts: 15
edited October 2003 in Car Subwoofer Talk
I am building a ported box tuned to 39hz for 4 12" subwoofers, in 2 separate chambers. It was recommended to me that all the woofers and ports be on the same plane, and that i'd get more bass if everything was firing back. I don't have the room for this...but i can fire 2 subs and 2 slots facing back, and 2 subs facing up. Am I taking too much risk here?...or should I just face everything up?
Post edited by b_knockwood on
  • Jstas
    Jstas Posts: 14,985
    edited October 2003
    Ideal placement is determined on an application by application basis. There is no "ideal" placement but whatever works best for your rig. If that means you only have the space to fire two subs up and two subs to the back then that would be the ideal configuration for you. Besides, 4 12inch subs are going to be so powerful, it won't matter which way they are facing. It'll be hard NOT to hear them!
    Just some ideas if you are really that concerned. I am assuming that these will be in a trunk. If so, remove carpeting and other platisc/cardboard panels and Dynamat the living hell out of the trunk. Stick the Dynamat directly to metal though otherwise it doesn't work so well. Also, make sure that the rubber weatherstripping around the trunk or hatch lid is in good shape. If not, spend some money and replace it with new stuff if you can. Also, get some of those rubber furtiture feet from Home Depot. The smalle ones, about the size of a dime. Drill a hole in the center big enough to fit your license plate screws through. Then unmount your license plate and put the rubber feet between teh plat and teh mounting point and screw the plat back on. That should help eliminate any vibration cause by the speakers vibrating the trunk lid.
    Expert Moron Extraordinaire
  • MTXMAN
    MTXMAN Posts: 682
    edited October 2003
    you can also put a layer of dynamat on the back of the plate and just make sure it's screwed down tightly
    Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
  • eddie_habeck
    eddie_habeck Posts: 21
    edited October 2003
    wow those are both great license plate tips.
    Car Sound & Performance Magazine
    www.eddiehabeck.com
    www.teamallstars.com
  • b_knockwood
    edited October 2003
    Thanks for all the great tips dudes.
    My last question is, I've noticed that most enclosures are wedge shaped, but some ported enclosures are also square. What is the difference?
  • Jstas
    Jstas Posts: 14,985
    edited October 2003
    Um...the shape? The major factor in an enclosure is the volume of the chamber. It can be any shape, within reason of course, as long as that shape has an internal volume matching the specs from the speaker going into it.
