Rookie question
boomerfss
I dusted off my old record player and added it to my system. Thought I would give two channel a try. Anyway, the songs sounded a bit lispy at higher volumes. Listening to the same music when streaming didn't have any lispy sounds. I did like how warm the music sounded from vinyl and would like to get back into listening to my old records.
Just wondering if the record player should be replaced or if there is a system deficiency.
Thanks.
I have a Onkyo HTRC 180 with polk Monitor 70's.
Thanks.
Onkyo HTRC 180
Polk Monitor 70 Series 2 Fronts
Polk CSi A6 Center
Polk PSW505 Sub Woofer
Polk Monitor 60 Series 2 Surrounds.
Harman Kardon HTSK18 Back Ceiling Mounted
PS3 Xbox
Polk CSi A6 Center
PS3 Xbox
Post edited by boomerfss on
Gonna need more info.
What is the TT? How is it hooked up and to what?
Is the needle/cartridge in good shape or been cleaned?
Lots of little stuff when getting into vinyl again.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
In my somewhat limited experience. The "lispy" sound your hearing is called sibilance. It can be caused from a record player not being set up properly, but also can vary from recording to recording. On my system there are a few records where the sibilance is fairly prominent, but most are not noticeable.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Oh, it's certainly an old turntable that's never been serviced. I guess I will start with that. Maybe buy a new one. Any recommendations for something in the $200 range?Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox -
It could be that you only need a new cartridge as some have issues from age. What is the turntable and cartridge right now. Certainly a new one is an option, but some of the older ones cAN be as good as anything new in your price range with a little TLC.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
It's a Kenwood KD 26r. I'm not even sure how old it is.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox -
The Kenwood KD 26 series were very basic tables. There are sites that have replacement belts and needles for your table for about $25.00 each. I am not sure you will be where you want to be even with these improvements. A basic TT, new, will run around $400.00 when it includes a cartridge. These are tables from companies like Rega, Project, and others. You can look on the Needle Doctor website, Music Direct's site and others. Another path to consider is to find a nice Techniques 1200 series used direct drive table that has not been used/abused in DJ work. These turn up local on Craigs list soemtimes. Very solid tables with good arms and well supported with aftermarket parts and upgrades if you ever decide to go down that path.
Rickintegrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
Thanks Rick.
I was looking at a Rega turntable at a local av store. It sells for about 450. It was hooked up to some B and W 685 speakers and it sounded amazing. Even the wife was impressed. I think I will go back for another look.
Cheers,
Jim.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox -
It does sound like sibilance, but have you tried cleaning the needle? Any record player that hasn't been used for awhile needs to have the needle dusted, etc. They're very finicky about that.
I'd also try another cable, just to be sure. -
If you hear the sibilance on only a few records, it could be a bad pressing. If you hear it all the time on every record, it is probably that your cartridge is not aligned correctly. If the stylus (needle) is very old and you cannot verify that it still has life left, you should start by replacing the stylus. Correct alignment of the cartridge is critical.Main System:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8 & FB210 ~
(2) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Marantz DV6001 ~ EPI M90 ~ Polk Audio RT35i ~ CS400i ~ (2) Polk Audio PSW450 -
Thanks guys. I'll have a look at it today.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox -
I was looking at a Rega turntable at a local av store. It sells for about 450. It was hooked up to some B and W 685 speakers and it sounded amazing. Even the wife was impressed. I think I will go back for another look...
TonySamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
BJC 10 ga - LCR mids “Foamed & Plugged**”, inside* & out
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
It's the Rega P1 and it does come with the cartridge and tone arm for $459, I just called to re-check. Here is the link. http://www.hificentre.com/Products-Services/High-Performance-Audio/Turntables/Rega.aspxOnkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox
