Tagging for Squeezebox use
rromeo923
rromeo923 Posts: 1,513
edited July 2012 in 2 Channel Audio
I noticed that I have quite a few songs/albums that my squeezebox does not recognize. What is the best way to tag these so they appear correctly in My Music.
Thanks!
I got static in my head
Post edited by rromeo923 on
  • Syndil
    Syndil Posts: 1,582
    edited July 2012
    MediaMonkey.
  • Drenis
    Drenis Posts: 2,871
    edited July 2012
    Syndil wrote: »
    MediaMonkey.
    There Auto-Tag service sucks. Manual tagging is very fluent though.
  • Syndil
    Syndil Posts: 1,582
    edited July 2012
    What? The auto-tagging is exactly why I recommended it. I use CTRL-L (Auto-tag from Amazon.com) and have mostly been pleased with the results. Apparently YMMV.
    heiney9 Posts: 25,221
    edited July 2012
    Drenis wrote: »
    Auto-tag works pretty well for me. I do have some things that I like to add some info for my own use. But generally it works pretty well. I pull data info from Freedb and cover art from Amazon.
    Ocassionally someone will do the song titles and everything in all caps, but in general Freedb database is pretty comprehensive.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2012
    I've said it before but I hate auto tagging. I don't want someone else deciding what my tags should be. I don't want 8 different genres of 'Rock', I just want the one. I use an automated process that creates the tag information based on the folder structure and filename of the song.
    It's easy, fast, and gives me exactly what I want 100% of the time with not a single error or flaw. When I rip a CD it adds all of about 1 minute to the whole process and gives me exactly what I want.
    edited July 2012
    I do the same thing, I let the auto-tag pull in the info and then I tweak it if it needs to be. It usually needs some minor tweaking for it to be 100% consistent with the rest of my tagged music.
  • Drenis
    Drenis Posts: 2,871
    edited July 2012
    heiney9 wrote: »
    How do you do that? I can only get info from five different Amazon sites. I've never seen an option to change this. Mind you, I only have the free version so I could be limited. The results are never the right album half the time. Once I accidentally killed a Georgia Satellites album because I hit okay. It re-tagged the songs improperly and mixed the actual track order. Had to revise the track numbers AND titles for all songs and the auto-tag STILL couldn't pick up the album.
    edited July 2012
    You know, I pull the tags in from dB Poweramp and then I tweak them in Media Monkey later if need be. dB Poweramp pulls from the FreedB database. I also get the cover art from FreedB as well, but at times if the image is poor I'll used MM to search all the Amazon sites for the best art work.
  • kappclark
    kappclark Posts: 136
    edited July 2012
    I use MM, and I auto-tag from filename...I find it very convenient for bulk-tagging
    ** Bill Clark Windham, VT **
    SCompRacer Posts: 8,520
    edited July 2012
    heiney9 wrote: »
    Yo...I pull the tags in from dB Poweramp
    Sometimes I use and really like the right click Edit ID-Tag feature dBpoweramp installs too. You can edit individual or all tracks in the specific album folder.
  • PrazVT
    PrazVT Posts: 1,606
    edited July 2012
    I've been using Tag & Rename for a few years (paid for it). A lot of features and I do it manually for each album. In the few instances album art isn't available, I just google for a ~ 500x500 image.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
