My first Home theater!
Mcneil999
Mcneil999 Posts: 1
Hello Everybody!
I just purchased panasoni1326k which is supposed to be the same as the vsx-53 and i was wondering if bi-ampin my new polk audio RM 6750 was worth it im new and don't know if it will wrok and wether or not it would be a good idea and if so how do you do it? Are Banana plugs worth it or is there another plug type i should buy?
Anyhow any help would be greatly appreciated!
Thanks a lot I can't wait to try it out!!!
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2012
    First, your receiver is a PIONEER, not a Panasoni (Panasonic?). Yes it is just a rebadged VSX-53, which is a decent receiver.
    Second, you can't biamp the RM 6750 - they only have one set of binding posts. So no, it will not work, don't do it.
    Lastly, banana plugs are worth it, however you'd only be able to use them on the receiver's outputs. The speakers nor the sub have banana plug connectors. Use bare wire on those.
    Main Surround -
