Parasound HCA-750A
VR3
VR3 Posts: 28,796
edited July 2012 in For Sale (FS) Classifieds
For your consideration is a Parasound HCA-750A in EXCELLENT condition, except for a small "ding" right above the power switch on the edge of the faceplate, I have been using this amplifier for several months now in my system with great results.
I have powered Polk LSi9 with this amplifier with ease... do not let the wattage fool you - it is underrated and clean.
This amplifier is capable of being bridged as well.
See below for specs -
Looking for $170.00 SHIPPED WITH PAYPAL
FEATURES
Direct Coupled -- no capacitors or inductors in signal path
Input stage uses hand matched complementary JFETs
8 beta-matched 15 amp, 50 MHz bipolar output transistors
500 VA Toroid power transformer with independent secondary windings for each channel, 28,000 ?F power supply filter capacitance
Independent power supplies for each channel
DC Servo and relay protection circuits
High bias Class A/AB operation
AC present, standby/normal, current overload indicators
Tiffany-style RCA input jacks, loop output jacks
12 volt DC automatic turn-on circuitry
Gold-plated 5 way speaker binding posts
Custom designed removable IEC AC cord
Rear mounted gain controls; ground lift switch
2 rack space height front panel
Rack mounting adapter available
SPECIFICATIONS
Continuous Power Output - Stereo:
75 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven;
125 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Continuous Power Output - Mono:
250 watts RMS, 20 Hz - 20 kHz, 8 Ω
Current Capacity:
20 amperes peak per channel
Slew Rate:
> 130 V/?second
Power Bandwith:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
< 0.06 % at full power; < 0.03 % typical levels
IM Distortion:
< 0.04 %
TIM:
unmeasurable
Dynamic Headroom:
> 1.5 dB
Interchannel Crosstalk:
> 80 dB at 1 kHz;
> 63 dB at 20 kHz
Input Sensitivity:
0.775V for full output
Input Impedance:
33 k Ω
S/N Ratio:
> 110 dB, full power, input shorted, IHF A-weighted
Damping Factor:
> 800 at 20 Hz
Power Consumption:
240 watts
Dimensions:
w 17 1/4" x h 3 1/2" x d 13 1/4", h 4 1/8" with feet
Net Weight:
18 lb.
Post edited by VR3 on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited July 2012
    I so want this for my center, going to have to try and sell my Onkyo m-5200 first, we will see what happens. I'd jump on it now, but I just dumped money on the other hobby. If it's still around when I got the coin I will take it. If it sells before then, well, there are more fish in the sea. In the meantime GLWS. To you noobs with Adcoms this is the way to go, you will not have the slam of an Adcom, but will gain detail spades, even in the bass department.
    VR3 Posts: 28,796
    edited July 2012
    No problem man, let me know!
    This blows Adcom of the time period out of the water, no doubt about that! You speak the truth!
    VR3 Posts: 28,796
    edited July 2012
    BUMP!
    Tomorrow this bad boy goes on the GON!
    Thanks! :)
  • shumi02
    shumi02 Posts: 10
    edited July 2012
    Very nice amplifier!
  • davidlin
    davidlin Posts: 10
    edited July 2012
    Is it still available?
    VR3 Posts: 28,796
    edited July 2012
    I believe for right now I have decided to keep this little monster around!
    Sorry about not updating this!
  • davidlin
    davidlin Posts: 10
    edited July 2012
    VR3 wrote: »
    It is really a nice amp.
