Bandpass vs Ported with mm2124
![Systems](https://us.v-cdn.net/5021930/uploads/userpics/442/n2E1QK3X8PYBE.jpg)
Systems
hello i have the option to use a ported box with the subs inverted or a band pass i do like sound quality i have infinity kappa perfect series componenets will a band pass sound good enough from 80-90hz and lower and will the band pass do low frequency hz as well such as 30-20hz ? i listen to lots of different music but i want the bass loud
Testing
Testing
Testing
Testing
Testing
Depends on the box chambers size and the port tuning freq. for the band pass freq range.Pioneer Premier DEH-P860MP
2 Polk Audio MM2124's
More to come... -
If you like sound quality I'd stick with the ported over the bandpass. 30 to 20hz sounds best in a sealed enclosure though, I think..Testing
Testing
Testing
