psw250 connections
finnyb
finnyb Posts: 3
Hi
just recently bought a denon reciever, and have a psw 250 sub, cant seem to figure out how to hook it up. Any help would be appreciated thanks
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited July 2012
    Hello finnyb,
    Welcome to Polk's forum, the PSW250 is a classic. Is the Denon receiver an older unit or a newer one? Can you give us the receiver's model number?
    Regards, Ken
  • finnyb
    finnyb Posts: 3
    edited July 2012
    Thanks Ken
    the denon is an avr-1312
  • [Deleted User]
    edited July 2012
    Hello finnyb,
    In looking at the receiver's owner's manual there is a subwoofer connection on the rear panel in the lower left hand corner. You would need a single RCA cable to go from this connection to either the right or left line level input on the sub (either one is fine). I can't remember if the PSW250 has a variable low pass filter or not, if it does rotate this control to the maximum setting. You may need to go into the receiver's setup menu and turn the sub-out function on. That should do it.
    Regards, Ken
  • finnyb
    finnyb Posts: 3
    edited July 2012
    Thanks Ken. It worked! I had it hooked up but the was no sound from the sub. Went to settings on the reciever and changed the sub setting. Working fine now. Thanks again for your help!
  • [Deleted User]
    edited July 2012
    No problem, glad to be of help.
    Enjoy!
  • DGBsr
    DGBsr Posts: 1
    edited July 2024
    Smoking transformer any suggestions or worth rebuilding or find a new one
  • Lanry
    Lanry Posts: 1
    I just bought the PSW250 sub. Please can someone help with what type of cable do i need to connect to my Sony TV.
    pitdogg2 Posts: 27,921
    Directly to a TV? What Sony TV?
    Going to need more info.
