Decisions
EndersShadow
EndersShadow Posts: 17,704
edited July 2012 in Speakers
So I picked up a Carver M1.0t amp thats on its way to me :cheesygrin:. That finishes up the amp dilemma for right now :biggrin:. I have enough cash to probably get it refurbished so its good to go for years. Here's the dilemma, I found a Sunfire True Subwoofer MK II sub for what I consider a very good price. Its NOT local to me, but I will be traveling to where its at for work next week.
I am curious how this sub compares to my PSW125. I obviously want to make sure its an upgrade otherwise I will either get my M1.0t refurbished or try to get another one :eek:
Post edited by EndersShadow on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2012
    That Sunfire is a very nice compact sub. There's no comparison between the 125 and it IMO, the Sunfire is in another league altogether. It's not even really fair to compare them though given their prices...
    edited July 2012
    Well the MK II I found is used and its going for less than I paid for my PSW125 new.
    I am just trying to see if I should get the amp refurbed and stick with my PSW125 or get the Sunfire, sell my PSW125 and use that money as a starter fund for a an amp refurb.
  • Drenis
    Drenis Posts: 2,871
    edited July 2012
    The amp is mint is it not? I can't remember if I asked you or not. Flip the sub and save for a amp service. It's a win-win scenario.
  • rooftop59
    rooftop59 Posts: 8,121
    edited July 2012
    I have never heard a sunfire sub, so what I say is based on a fair amount of internet research since the size and output of those subs put them on my short list for awhile. Based on the reviews, I will concur with Danny. This sub should hit 18-20 hz at more than 100 db, where your current sub can maybe hit 30 hz at 90ish db?? So yes it should be a major upgrade for ht. But the other thing to consider is that those sunfire subs are known for having amp problems somewhere down the road, and sunfire wants something like 600 bones to fix the amp. This is why there are lots of sunfire sub parts (cabs and drivers) on ebay all the time.
    I think drenis has a good suggestion; flip the sub and use the money to save for a more reliable sub. But again, take my advice with a grain of salt...
    Game Room 5.1.4:
    Bedroom 2.1
  • AsSiMiLaTeD
    edited July 2012
    I've heard and spent lots of time with the Sunfire sub. It's a significant upgrade over the PSW125, it's not even close.
    pitdogg2 Posts: 27,026
    edited July 2012
    well here's some thought. Although I have never had a Sunfire sub (always wanted one) I gave up on them when I knew several friends that had one at one time or another. Many had problems and one fellow Polk forum member who I've talked with has one that although in good shape the amp is another story. Most can't be fixed So if it were me I'd get the serial number and give Roland a call and hash out the pros and cons of getting said unit....couldn't hurt.
    From what I understand some of the models parts are non-existent.
    edited July 2012
    Drenis wrote: »
    The amp is in working condition and looks darn near mint. I have enough now to upgrade it off the bat, though I dont think it needs it. I bought it from a trusted source.
    The sub is going for way under its normal asking price. I am going to look into it just because. I am reading up on the amps and whatnot.
    I might buy the Sunfire, keep it for a bit and then sell it if it works good.
    edited July 2012
    I will see about doing that. Sounds like a smart idea.
  • PSOVLSK
    PSOVLSK Posts: 5,379
    edited July 2012
    I'm very happy with my Sunfire. Unbelievable bass for the size. I paid $400 plus shipping (I think) and consider that to be a pretty good deal.
    I'd buy it and sell the 125.
    edited July 2012
    I put a bid in on another M1.0t. If that doesn't pan out we will see what I end up doing. I have time since I won't be able to pick up the sunfire till the 10th. If he won't demo it for me though it's a deal breaker.
