Soldering newbie here
rromeo923
rromeo923 Posts: 1,513
edited July 2012 in DIY, Mods & Tweaks
I was about to refoam my woofers on a pair of "The Smaller Advents" and have been thwarted by the fact that the wires to the woofer are soldered on. I have never soldered anything before. I think that this should be relatively easy and hard to mess up so I thought I might give it a shot.
Any suggestions for the type of Soldering kit I should buy? Do I need a separate desoldering kit?
Thanks!
I got static in my head
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2012
    A good iron is key, along with a clean tinned tip. As far as desoldering kit? I think a solder wick or a solder sucker maybe helpful and needed as you're a newbie.
    Youtube it and good luck.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • bmbguy
    bmbguy Posts: 416
    edited July 2012
    In my experience, solder wick is much easier to use than a solder sucker (depending on the amount of solder to be removed). However, some wick is better than others. The wick that is pre-treated with flux attracts solder much easier and faster than that without.
    Depending on the connection, you may be able to just heat it and remove the wires, then do some cleanup afterward. Or snip the wires off first, then clean up the terminals.
