Capacitor questions.
BentMike
BentMike Posts: 10
edited June 2012 in Speakers
I just re capped one of my Monitor 5A. I have a couple questions.
Any idea why the 12uF is physically bigger than the 34uF? I could imagine they asked for some that were longer just to span the PCB better. I got a couple of Jantzen 400V caps and they really show the difference I would expect.
Is there a down side to higher voltage caps? Also, I had to settle for a 33uF cap, how different is that 3% in the grand scheme? That cap is parallel with the woofer. Why would I want that effect? It will slow the rise across the driver and accelerate the dissipation when a wave passes, but it may be allowing the cone to travel farther? Increasing the low frequency response (with phase shift) and absorbing higher ones? Am I interpreting this right?
I did notice the new caps added some nearly inaudible, but felt lows compared to the speaker I have not re capped yet. I think that those lows are possible with such a small speaker is really cool. I never gave passive radiators much thought before this. But that is another topic and another list of questions.
Thanks for all your help!
BM
BentMike
Polk Audio Monitor 5A
Sansui SP-3500
NAD 1020 Preamp
Crown D- 75A Power Amp
Musiland Monitor USD --> FiiO DAC
Post edited by BentMike on
    F1nut Posts: 51,723
    edited June 2012
    The 12 is mylar, the 34 is electrolytic.
    They are larger.
    It's well within the original +/-10% tolerance, so not really a concern. That said, I like my caps to be +/-1% just 'cause.
    Wait until you do both speakers and get at least 200 hours on them before judging. You did the resistor(s) too, right?
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited June 2012
    U can add a 1 uf cap " piggie backed with the 33 to give u yhe 34 uf u need.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • skrol
    skrol Posts: 3,442
    edited June 2012
    You would be better off evenly splitting the capacitance and placing 2 in parallel (ie. 17uF + 17uF = 34uF). I know that the math comes out the same and PSpice does not show but sonically it is different and not good. I tried this when I did the XO's in my RTA11TL's. Actually, you would be better off just going with the 33uF as it is only 3% off which is far better than the originals when new.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 51,723
    edited June 2012
    Exactly. The large difference between the 33uF and the 1uF has the 1uF acting like a bypass cap.
