Terminal cups for 2B
gmcman
gmcman Posts: 1,807
edited June 2012 in Vintage Speakers
I was thinking that instead of hacking up my original terminal cups to add some binding posts and an upgraded IC cable post, that I would find an aftermarket cup if there is one that fits.
I could remove mine but curious if someone already knows the dimensions or if there is a direct fit replacement.
Post edited by gmcman on
    VR3 Posts: 28,788
    edited June 2012
    There unfortunately is not an exact drop in that I know of -
    I do know you do not have to hack anything up, alot of modern parts will drop right in!
    Toolfan66 Posts: 17,336
    edited June 2012
    Once you upgrade you will never put the originals back in anyway so I wouldn't worry about it.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • gmcman
    gmcman Posts: 1,807
    edited June 2012
    Toolfan66 wrote: »
    Yeah.....I'm sure you are correct. Something about keeping the speaker original just weighs in on me. I'm mainly after changing the IC cable post to a banana or spade post. Granted the speaker has been modded it's no longer original but was hoping there was a drop-in replacement cup.
    I will get in there this week and change out the pin terminal.
    F1nut Posts: 50,755
    edited June 2012
    gmcman wrote: »
    I felt the same way for the longest time, but I just recently said eff it. I never liked the binding post idea, so I'm changing the pin/blade stuff out for some Neutrik Speakon connections.
