Which drywall model to replace monitor 30 surround?
silx
silx Posts: 2
edited June 2012 in Speakers
hi,
I am going to live in another home this year and I don't have much space to monitor 30 surround, so I need to replace it for a drywall model. I don't have any idea about a good drywall model to replace monitor 30, does anybody can help me please? (receiver: yamaha htr6240, front speakers: monitor 30, center channel: polk cs1)
I found this 2 models by jbl and polk... specifications of monitor 30 and 2 dry wall model bellow.
(Sorry my english, I from Brazil.)
POLK MONITOR 30
Driver Complement
Mid/Woofer 1 - 5-1/4" Diameter (13.34cm)
Dynamic Balance Bi-laminate composite cone driver, magnetically shielded
Tweeter 1 - 1" Diameter (2.54cm)
Dynamic Balance Silk/polymer composite dome, magnetically shielded
Electrical
Overall Frequency Response 55Hz - 25kHz
Lower -3dB Limit 63Hz
Upper -3dB Limit 24kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20 -100 w/channel
Efficiency 89 dB
Crossover 2.3kHz, second order high and low pass
Inputs Dual (bi-amp) 5 way binding posts
Jbl Sp 6 dry wall model
- Sensitivity (2.83V @ 1m) 88dB
- Low-Frequency Driver 6-1/2" Titanium-laminate cone with rubber surround
- High-Frequency Driver 1" Titanium-laminate dome with EOS? waveguide and swivel mount
- Maximum Recommended Amplifier Power 80 Watts
- Frequency Response (?10dB) 38Hz ? 20kHz
- Crossover Frequency 2.8kHz
Plate Size (W x H) 8-1/2" x 11"
(216mm x 279mm)
- Mounting Cutout Size, (W x H) 7-1/8" x 9-11/16", (181mm x 246mm)
- Mounting Depth 3-7/8" (98mm)
POLK RC55I dry wall model
Dynamic Balance, mineral filled Polymer cone with rubber surround
Tweeter 1 - 3/4" Diameter (1.91cm)
Dynamic Balance, metalized soft dome in swivel mount
Electrical
Overall Frequency Response 67Hz - 20kHz
Lower -3dB Limit 70Hz
Upper -3dB Limit 20kHz
Recommended Amplifier Power 20 - 100 w/channel
Efficiency 90 dB
Dimensions
Size 11" H x 7-9/16" W
(27.94cm H x 19.21cm W)
Cut-out Size 9-5/8" H x 6-1/4" W
(24.45cm H x 15.88cm W)
Mounting Depth
(assumes 1/2" [12.7mm] wall material) 2" (5.08cm)
Overall Depth 2-1/2" (6.35cm)
Post edited by silx on
