Sold my subwoofer. Can my RTA12's handle a lot of bass?
HTguru1982
HTguru1982 Posts: 1,066
edited June 2012 in Vintage Speakers
I sold my Sonance subwoofer to finance the purchase of another sub. But before buying one, I decided to run the RTA12's as large with all of the low frequencies going to them and I have to say that I'm pleasantly surprised. While they don't rattle the walls, the bass is surprisingly tight and tuneful, more so than with the Sonance I had. So instead of buying another sub, I may just use that money to replace all of my SL2000's with RD0-194's.
So is it safe to run the RTA12's this way? The system is used mainly for movies. They are being driven with an Adcom GFA-6000 so power isn't an issue.
Thanks in advance!
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
  • drumminman
    drumminman Posts: 3,396
    edited June 2012
    That's how I run mine, and I've had no issues. However I also use a subwoofer. Running the RTA 12's full range and filling in the bottom with the sub makes it very easy to dial in the sub.
    VR3 Posts: 29,752
    edited June 2012
    You should be fine but if you are a Reference Level watcher I would use caution
