4 ohm or 6 ohm setting on 709
I have tsi400 fronts cs10 center & bose 100 for surround for now all are 8 ohm spkr's. Can you tell me in the settings on
onkyo 709 do I use 4 ohm or 6 ohm setting & what crossover setting do I use? thks!!!
Post edited by onbreake8 on
Welcome to Club Polk!
The 6 ohm setting on the Onkyo covers 6-8 ohm speakers. So that is the setting you should use! Start with your sub crossover at 80hz (all the way around) and see how that sounds. That should be good enough! Good luck and stick around! Lots of info, good people and good times on this site!
