Lite Audio Dac 60 w/ Pacific Valve mods
dhart86
includes Siemen 6922 tubes (NOS) excellent sounding tube
This is a great sounding dac with added tube warmth. I had it modded to upgrade caps etc and while there a new audio board was put in as well.
Therefore, this is basically a brand new dac with about 47 hrs on it. Dac is in excellent mechanical and cosmetic condition.
I am selling this unit because I love the Wyred 4 Sound Dac 2 I have and will be trying to get another for the bedroom rig
Selling for $375 = Shipping (I'll eat PP fees)
Stock Product Description:
DAC60 chip use famous PCM1704, at the same level of world's top DAC . Packaging technology use of modern SMD package,DAC 60 can accept 44.1 kHz ~ 96kHz signal. Acceptable quality equivalent to DVD AUDIO.Line architecture, the digital part of the selection of the most trusted 96kHz receiver, model CS8414, with precision external oscillator, so JITTER minimum, to ensure the purity of music. With DF1704, finally into the super decoder chip PCM1704, machine design are using the highest quality chips on the market,Output components using vacuum tubes to do, completely avoid the impact of IC, but also to avoid using a lot of negative feedback, resulting in loss of detail. Line structure with two 6DJ8 SRPP continue to do the output, the output amplitude large, S / N ratio is extremely high, also has low output impedance and, more importantly, the analog signal output is completely handled by a simple vacuum tube, there is no trace of any the composition of the crystal or IC.
The product specification:
Size/material: iron box shell long 405 mm x deep 290 mm x 100 mm high (including feet tall). Aluminum panel (thickness 10 mm x long 430 mm x 80 mm high).
Gross: about 8kg
Digital input terminals: optical + coaxial.
output terminals: RCA.
The vacuum tube type: 6 DJ8 * 2 (or 6922, such as ECC88 same tube)
Gross: about 8kg
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Second Rig:
Post edited by dhart86 on
Main Rig:
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Main Rig:
Second Rig:
Hi David, I'd be interested. Is shipment to europe possible? We can share the cost of shipment, otherwise I'm ok to come up for it.
Can do advance payment via Paypal.
All the best,
Phil -
All the best,
Phil
Phil, I am sending you a pmMain Rig:
Second Rig:
SOLD!
Mods, please mark this unit as soldMain Rig:
Second Rig:
