Setup with no sub
torotot
I have the Panasonic SC-HT400 Receiver shown in the link below. I also have the RTi6 for fronts, CSi3 for center and the stock surrounds that came with the Panasonic package.
http://www.panasonic.ca/english/audiovideo/audio/hometheatre/scht400.asp
I finally bought the PSW404 subwoofer. I noticed that I do not have the SUB OUT RCA on the receiver. I only have one speaker out for the subwoofer so I have connected this to 1 of the 2 speaker inputs of the subwoofer. Is this the best way to hook the system up?
What is the optimum cut off frequency for the front speakers (RTi6)?
Post edited by torotot on
You only have one choice - speaker level connection.
I would imagine the Panny AVR does all the bass management and blends the subwoofer XO with the rest of the channels. It is probably around 150 Hz.
I would not use the filter on the subwoofer; set it to the highest setting and let the Panny figure out the rest.
A better AVR will have more conventional BM and will allow you to get more from your Polk speakers and 404 sub."What we do in life echoes in eternity"
SVS -
What is "one speaker out for the subwoofer"? Isn't this the sub out RCA? I am confused.Graham
It's an unpowered subwoofer that the receiver powers with a 6th channel from its amp.
So you connect it like a regular speaker.
The RCA connection uses a low voltage (millivolt) signal to the subwoofer's separate amplifier."What we do in life echoes in eternity"
SVS -
Thanks Doc , I understand now. I hadn't heard of this before.Graham
