height placement of center channel speaker?
bulldog
Is there a "correct" height to place a center channel? Should it be placed above or below the TV?
I am about to purchase a BDI Vector stand and I would be forced to place my Polk CS400 below the TV. This would result in my center channel at 15-16 inches from the floor.
Should I be concerned?
Post edited by bulldog on
Not really. Try using a couple of rubber door stops to angle the speaker upwards if the dialogue seems to be comming from below the screen.
A general "rule of thumb" is to have the tweeter of your center within 2 feet, either above or below, the tweeters of your main speakers.Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection -
That being said, real world restrictions (read WAF) and room dimensions will often dictate where your center channel goes. Case in point, I flush mounted my Csi40 above my Sony XBR40. This actually puts it about 4.5 feet above my Rti8 tweeters. It sounds great, IMO.
