1st pair of sda's
soundfreak1
As above will be getting my 1st pair of sda 1's ( not sure of which version,till i het them. )Will be making a cable too test them but is thier am optium distance of seporation? Im sure when new the factory cable was at a spacific length, but being my first i have no idea of that length. Is thier a optium distance if so what is recomended. Thanks
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
My SDA 2b manual states 4-20 feet apart. It says you should place them apart the same distance as you will be sitting away from them. I have mine about 10 feet apart and sit 10 feet away with great results. It also says to keep them at least 3 feet from a side wall and place them against the back wall. Hope this helps.
Yes it does thank u. Just was concerned about impedence in the sda cable but of it ok out to 20 feet than it not an issue for me
thanks again.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
