Morrow Audio cables?
danz1906
danz1906 Posts: 5,144
edited June 2012 in 2 Channel Audio
Hey Guys,
Is anyone familiar with the Morrow Audio cables?
If so, how are the MA cables?
How do the MA's compare to similarly priced Audioquest,MIT or Kmber cables?
http://www.morrowaudio.com/cables.htm
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
Post edited by danz1906 on
  • playback
    playback Posts: 101
    edited June 2012
    danz1906 wrote: »
    Hey Guys,
    I have MA3 balanced and the Sp3 biwire speaker cable, I also have balanced/rca Audioquest Columbia and a set of King Cobra rca's, and Coral rca as well. After a rather longish burn in 400hrs I can tell you that after a year these MA3 ic's have been in my setup I will replace all my AQ stuff with the Morrow's they just excel at musical purity and tonality with shades across the spectrum they can be warm when called for and detailed if necessary image weight and scale and are dead quiet ( this is the MA3's description) I previously tried the MA2's before the MA3 and while the mids and highs are to die for, the MA3 hit the sweet spot top to bottom with greater extension. I say go for it mike is a great guy to deal with and has a generous 60 day return policy!Try the MA3's and up and post back!
  • danz1906
    edited June 2012
    Playback,
    Thanks for the info, I'm thinking of getting the MA4 balanced cables.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • playback
    playback Posts: 101
    edited June 2012
    Sweet, Take the longish burn in serious and opt for the burn in service if you can swing it. Let me know what you find.
  • playback
    playback Posts: 101
    edited June 2012
    Oh did I mention they kill on Home theater playback musical scores and dynamics!
  • danz1906
    edited June 2012
    playback wrote: »
    Sweet, trying to get a deal on Audiogon!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
