Simple Wiring HELP!
tigers4life
Just took a set of component speakers out of the box, and I don't even know how to hook the wires into the crossover! The crossover has screws, and there are several bundles of wires that accompany. I know some basics about wiring speakers, but this crossover stuff is all new. I don't have an amplifier. I'm simply going for better sound from an aftermarket head-unit. I know which wires go to the woofers and tweeters. Are the other two from the head-unit? Lastly, how do I connect the wires to the crossover? Some of the wires have different ends. Thanks in advance!
Post edited by tigers4life on
Just a suggestion, but you might want to ask a mod to move this to the car audio section. You will probably get a better answer there than in the basic hookup section.
A quick look at the instruction sheet wouldn't hurt!!!!If you can't hear a difference, don't waste your money.
