vintage brochures
rick57
Looking for vintage brochures/manuals for original monitor line...circa 1978-79.
Also...just picked up a nice set of 7a's...need to clean.
What is best for cleaning cabinet (vinyl) and mid/bass drivers?
Don't want to damage.
Thanks.
Thanks.
Post edited by rick57 on
Welcome to Club Polk!
Not sure about the cabinet as vinyl is pretty easy to clean with most things.
But most people recommend a little windex on the drivers (NOT THE TWEETER, though) as they're pretty well protecting with that doping.
But I'd wait to get a "second" opinion on that before I go ahead!
thanks!
Lots of windex on a paper towel. Wipe the driver very gently in a circular motion around the dust cap to get it wet/damp. Then after about a minute wipe it again with the windex soaked paper towel (in the same way). I cleaned 4 extreamly dusty and dirty drivers using this method and they now look almost new. I have found that getting it pretty wet with windex makes the cleaning easier as long as you don't go nuts.
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
