Signal Analog 2 or Silver Resolution speaker cables?
gwg_97
gwg_97 Posts: 332
edited June 2012 in 2 Channel Audio
Opinions please.
I'm trying to decide between the Signal Analog 2 and the Silver Resolution speaker cables (for my 2 channel rig). What do you guys think in terms of bang for the buck? Do you think the Silver Resolution might be a bit to detailed (harsh) for my Carver gear and modded SDA 1Cs (Sonicaps and Mills)? I have a silver SDA cable and I think it made a pretty big difference compared to the stock cable.
Thanks!
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
Post edited by gwg_97 on
  • pearsall001
    pearsall001 Posts: 5,094
    edited June 2012
    I would suggest picking up a pair of each & do a side by side comparison. Frank has a great return policy & also gives Polkies a discount. Let your ears decide for you.
  • gwg_97
    gwg_97 Posts: 332
    edited June 2012
    Yeah, that's definitely an option but for some reason I would feel a little bad about "demoing" some new cables and then returning them. Call me weird:biggrin:.
    I didn't know about the CP discount. How much? Thanks for the tip!
    EndersShadow Posts: 17,596
    edited June 2012
    I think its like 10% off or something like that.... call him and ask :wink:
  • pearsall001
    edited June 2012
    Don't quote me but I think it's a 5% discount. Talk to Frank, he'll probably recommend that you try them both & won't have a problem with you returning one.
  • Conradicles
    Conradicles Posts: 6,143
    edited June 2012
    I've used both many times and my choice is the silver resolution. Sweet cable.
  • gwg_97
    gwg_97 Posts: 332
    edited June 2012
    Alright! Thanks fpr the help guys!
  • dkg999
    dkg999 Posts: 5,647
    edited June 2012
    Call Frank and ask him. He normally can provide good recommendations. I have great respect for people like Frank who could of sold me the most expensive cable he had but didn't because he didn't feel it would work with my gear and my tastes.
    DKG999
  • gwg_97
    gwg_97 Posts: 332
    edited June 2012
    dkg999 wrote: »
    I'll give Frank a buzz and see what he has to say. Thanks!
