M5 Woofer/Tweeter question
Hi All,
How does one go about removing the woofer and tweeter from an M5? I picked up a pair from a yard sale one of the tweeters is shot (or the crossover itself is) and I want to replace it if at all possible. From looking at the speakers themselves, it just looks like you pry the side of the housing away from the woofer/tweeter mounting plate and pop the part out (there aren't any visible screws on the housing at all).
Is that all there is to do, or is there a specific method to use to go about breaking these units down?
Thanks!
Thanks!
Post edited by MikeMcG on
Okay - never mind, I figured it out...
