Speaker Stand Recommendations for LSiM 703?
RocketOCannon
Does anyone know which model and make PA uses for the 703 when they do shows?
Any other stands that you may know that I should look at?
If you know model and make/item number, please mention it.
Thanks,
Thanks,
HOME THEATER 5.1
JVC DLARS56U
92" SI Black Diamond 1.4 16:9
NAD M25 MC Power Amp
Marantz AV7005 Pre Amp
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
LSIM 707 (2 Channel Sessions)
McIntosh MC312
McIntosh C49 Preamp
Marantz SA8005 SACD/CD Player
79' Pioneer SX-1080
Furman Elite 15 PC
Solidsteele HF-4 series rack
(Building system out currently)
OUTDOOR DECK
NAD C 375BEE DAQ
PSB CS 1000 Speakers
Sonos
Signal Cable - Ultra Single (Banana), Magic Power Cord, Dig Power, Vid Power.
RTi T3-V+, SONOS, Furman Power Conditioner
JVC DLARS56U
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
McIntosh MC312
McIntosh C49 Preamp
79' Pioneer SX-1080
Furman Elite 15 PC
OUTDOOR DECK
NAD C 375BEE DAQ
Sonos
Post edited by RocketOCannon on
I just spoke with PA CS.
I had 2 questions
1) Which brand or model does Pause typically or recommend.
Answer - Sanus...Ultimate Series...etc
2) How do you mount the speaker to the stand
Answer -
a. Use 2 sided sticky tape to bottom of speaker....
b. Drill holes...etc........wth...Really?
Is this how people mount beautiful speakers to stands?! ....sitting here bewildered.
Anybody have any thoughts? Advice? recommendations?
This seems like a huge disconecct between beautiful cabinets, $$$Spends...and caveman mounting.HOME THEATER 5.1
JVC DLARS56U
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
McIntosh MC312
McIntosh C49 Preamp
79' Pioneer SX-1080
Furman Elite 15 PC
OUTDOOR DECK
NAD C 375BEE DAQ
Sonos
RTi T3-V+, SONOS, Furman Power Conditioner -
I have mine sitting on Skylan Stands. http://www.skylanstands.com/stands.htm
Model SKY-20D built to 28" for me. Noel Nolan is the owner. Lots of good feedback about him and his products.Frank
Polk LSiM 703 mains on Skylan Stands
Polk LSiM 704c center
Polk FX500i surrounds
Parasound 5250 Amp
Oppo BDP-105
SVS PC Ultra tuned to 16hz
Panasonic 65" Viera Plasma -
Frank,
thanks for the reply and link. Those look real nice!
How did you mount your speakers? Ae they just sitting on the plate or did you attach your speakers somehow?
I...no matter what will NOT acre holes in my speakers! ...seems ludicrous to me....maybe Ive been away from the audio world to long and am going nuts....just my 2 cents. I needed I will wind up buying some nice cherry wood and build a nice little "Seat" for them. Then I can screw that to the plate, and still keep the speakers in a safe comfy position and look good too.
I would love to hear from others that have med to large bookies..how do you mount/use your stands?
Thanks again Frank!HOME THEATER 5.1
JVC DLARS56U
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
McIntosh MC312
McIntosh C49 Preamp
79' Pioneer SX-1080
Furman Elite 15 PC
OUTDOOR DECK
NAD C 375BEE DAQ
Sonos
I also have the Skylan stands at 28" tall. I use blu tak. The speakers are fairly secure and they don't budge unless you want them to. Its not bolting them down But it works...
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
If you don't have any pets or little curious fingers I'd say just place them on top without securing them. That's why I like floorstanders because I refuse to put holes in my speakers.
As noted, Skylan or Sanus Ultimate. I have a pair of each and highly recommend either. However, I think the LSiM's and the Skylan combo would look better. Noel is a great guy to work with, he'll make the column height and plates pretty much to your specs and he's a wealth of knowledge.
I use non-skid rubber pads between the stand and speaker.
Whichever one you go with be sure to mass load them. I use 25 lbs. of lead shot per stand.Political Correctness'.........defined
President of Club Polk -
Thanks for the info guys.
It makes sense now. The blue tak type of product will work.
I have a German Shepherd and 2 rug rats 8 & 10. I don't see it being a problem though.
I must say though...how in the world does an industry such as Audio get details and striving for perfection so right in so many ways arrive at this major disconnect in regards to having a system that effectively mounts speakers to a stand without drilling holes....absolutely floored by this.HOME THEATER 5.1
JVC DLARS56U
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
McIntosh MC312
McIntosh C49 Preamp
79' Pioneer SX-1080
Furman Elite 15 PC
OUTDOOR DECK
NAD C 375BEE DAQ
Sonos
RocketOCannon wrote: »I must say though...how in the world does an industry such as Audio get details and striving for perfection so right in so many ways arrive at this major disconnect in regards to having a system that effectively mounts speakers to a stand without drilling holes....absolutely floored by this.
They found a way around it.... they are called Floorstanding speakers ....
Just kidding I agree with you on this. The best systems I have seen to do are: Polks VM series with stands, the Sunfire CRM-2's that have customs stands you can buy, and the Paradigm Studio line with stands."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »They found a way around it.... they are called Floorstanding speakers ....
ender...lol...so true though...HOME THEATER 5.1
JVC DLARS56U
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
McIntosh MC312
McIntosh C49 Preamp
79' Pioneer SX-1080
Furman Elite 15 PC
OUTDOOR DECK
NAD C 375BEE DAQ
Sonos
The problem is that you can't have a universal method to attach a speaker to a stand as there are far too many variables.Political Correctness'.........defined
Nice thats my dream setup LSIM's iam just starting out have LSI25's and psw111 i would be intrested in those LSIC's when you sell
because drilling is one method to securely mount speakers. the other is paying a high markup on 1st party OEM stands/mounts or 3rd party mounts/stands. pick your poison. and floorstanding is one of the other 'workarounds'.
