Ok i need a turntable preamp expert
brgman
brgman Posts: 2,859
I have a new Rogue audio Ares pre and i have tried a few settings on the dip switches but i cannot seem to find where i am getting enough output.
I need to turn my pre up over 1/2 way to get decent volume where i go about a 1/4 on a cd.
I have a Dynavector cartridge.
here are the links on these-
http://www.dynavector.com/products/cart/e_20x.html
http://www.rogueaudio.com/documents/AresManual.doc
any input on settings is appreciated
I’M OFFENDED!!!!
Post edited by brgman on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited June 2012
    Hello,
    Do you have the "high" or "low" output version?
    Ken
  • brgman
    brgman Posts: 2,859
    edited June 2012
    High
    I’M OFFENDED!!!!
    mhardy6647 Posts: 35,314
    edited June 2012
    The line level outputs on "modern" CD players tend to be pretty "hot" (high level; 2V or more). The gain of your phono preamp may just not get you there. I don't see the difference as a big deal, unless you simply cannot get enough volume out of the system.
    A quick perusal of the manual suggests that you can always try the gain setting for a "medium output" MC cartridge (page 7).
    edited June 2012
    The line level outputs on "modern" CD players tend to be pretty "hot" (high level; 2V or more as compared to the ancient standard of 1 volt into 600 ohms). The gain of your phono preamp may just not get you there (EDIT although they claim that the preamp can put out 8V RMS - although they don't seem to spec the gain nor the input signal required for 8V RMS out). I don't see the difference as a big deal, unless you simply cannot get enough volume out of the system.
  • brgman
    brgman Posts: 2,859
    edited June 2012
    i can get what i need but wonder if i am pushing my tube amp further than i should since i need to go so far on the preamp volume knob
    I’M OFFENDED!!!!
    edited June 2012
