TSi Surrounds with Rti A Mains?
apoteker
apoteker Posts: 22
edited June 2012 in Speakers
I am setting up my HT system and will have RTi A7s for my main speakers and the CSi A6 for my center channel. Would OWM 5s and OWM 3s work as side and rear surrounds? Are they timbre matched to the RTi A series or should I look at the FXi A6?
Post edited by apoteker on
    txcoastal1 Posts: 13,505
    edited June 2012
    Could you use the OWM's? Yes
    But you will probably appreciate the FXi's much more. They have a bipole/dipole setting for location/reflection adjustment.
    How large is your room? Do you plan on 5.1 or 7.1 surround sound?
    Wecome to CP
  • B Run
    B Run Posts: 1,888
    edited June 2012
    The Fxi's will be a huge upgrade over the Owm's, but the Owm's will work fine. No they are not timbre matched, it's not crucial for the surrounds to be timbre matched but i'd take a 5.1 set with Fxi's vs a 7.1 set with Owms IMHO.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited June 2012
    B Run wrote: »
    Per the Polk OWM webpage:
    they're timbre-matched for smooth integration into Polk Audio systems
    Timbre-matched to what, they don't say...
  • jbooker82
    jbooker82 Posts: 1,627
    edited June 2012
    I would go with FXI A's for the side surrounds and a pair of RTi's for the rear if your doing 7.1. You could also go with a CSI A4 in the rear and do a 6.1
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • B Run
    B Run Posts: 1,888
    edited June 2012
    mdaudioguy wrote: »
    Good point, I just always considered them on par with the monitor series honestly.
  • apoteker
    apoteker Posts: 22
    edited June 2012
    txcoastal1 wrote: »
    Wecome to CP
    I plan to do 7.1 surround but it is a small room as home theaters go. I am converting unused space that is 14'8" x 14'6"...not the ideal situation but I have to work with what I have. Originally I was set to go with TSi 500s, CS20, OWM5s, and OWM3s. Long story short, one of the TSi 500s was damaged in shipping and my store can no longer get them. They offered to sell me the RTi A7s for $25 more per speaker. Now I'm in the process of deciding to A) go forward with the RTi A7s and return the CS20 and the OWMs and replace them with the CSi A6 and FXis OR B) just keep what I have and buy another TSi 500 from another vendor. My original thought was go for the RTi As and CSi A6 and possibly keep the OWMs but now I wonder if it is overkill for my needs. Thoughts?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited June 2012
    Go for the RTiA7s and if your budget and room layout work with the FXis - get 'em and don't look back.
  • chumlie
    chumlie Posts: 8,658
    edited June 2012
    Go with plan A. No such thing as overkill. You'll be glad you did.
  • apoteker
    apoteker Posts: 22
    edited June 2012
    Thanks for all of the feedback! It looks like RTi A speakers are the way to go. I do think that I will have to keep the OMW 3s for the rear surround for a 7.1 setup due to space constraints (and budget). I hope they will work OK for a while. Like the post above said, "they're timbre-matched for smooth integration into Polk Audio systems" but to what is anyone's guess.
  • chumlie
    edited June 2012
    You getting the FXi's too ? Or just going with the OMW's. Either way you'll be happy with the RTi, CSa setup. Get the FXi's and a good power amp when budget allows.
    edited June 2012
    Chumlie is right....if space is the issue then go with OMW's but if it's budget the just run what you can afford....baby steps till you get what you want is my motto
    Good luck
    Cheers
  • Upstatemax
    Upstatemax Posts: 2,735
    edited June 2012
    mdaudioguy wrote: »
    I pretty sure when they first came out they said that they were timbre matched to the Monitor series. Now the Monitor series is out of production, so they probably just threw that vague blanket statement in...
  • apoteker
    apoteker Posts: 22
    edited June 2012
    chumlie wrote: »
    Going to try to get the FXi A6 or A4 for my side surrounds and use the OMW 3s for the rear effects speakers. If it's not wise to mix the two then I'll probably just go with the OMW 5 for side surrounds and OMW 3 for rear effects. Your mention of a power amp brings up another good question...will my Onkyo TX-NR709 be enough of a receiver to run these speakers?
  • jbooker82
    edited June 2012
    apoteker wrote: »
    I would deffinalty mix and match over using all OMW's for surrounds. The FXI A4's and 6's are great side surround speakers. I woudlnt trade them for OMW's just to keep with all OMW surrounds.
    Your Onkyo will run them fine. Later on if you want to upgrade you can always add an external amplifer since your avr has pre outs. The newer onkyo's hold their power better when you compair the factory rated 2 channel, and the Home Theater Magazine 5 and 7 channel power ratings.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • chumlie
    edited June 2012
    You may find you don't even need or want the OMW's if you get a pair of FXi's. I would go with a 5.1 with the FXi's first, then decide if you still want the rear effects. The FXi' throw the sound around. As far as amps go. You really don't need one BUT it will bring out the best in those speakers. You will get a noticeabley improved difference in sound if you decide to add an amp or amps later. jbooker likes Carver, i like Parasound and others swear by Emotiva. Its really up to your ears and wallet to decide. I thought the a7's sounded great with my reciever but i fell into the rabit hole too. Still digging i might add. Get the best ya can now and add on later or save up to get what ya want because buyer remorse sucks.
