Snell Type D for Dared MP5 ?
vcwatkins
vcwatkins Posts: 1,992
edited May 2012 in 2 Channel Audio
I recently picked up a Dared MP-5 clone and am considering possible speakers for this great little integrated. I have some 5b's that need a lot of work and, until they're done, would like to consider trying some others. Here are specs pasted for the Fatman equivalent:
Power Output - 13 watts x 2 ch.
- Frequency Response 20Hz - 20KHz (±1.5dB)
- Harmonic Distortion 0.5%
- Signal-To-Noise Ratio 86dB
- Input Impedance 100K - Output Impedance 4ohm, 8ohm
- Valve Type 2 x 6N1(ECC85 - currently NOS 60's (Siemens) RCA's) 1 x 6E2(EM87)
- Power Supply AC100~120V/50~60Hz AC220~240V/50~60Hz
I have a buddy that is willing to sell me his Snell Type D's at well below market value. I've heard them maybe twice, but it was so brief and long ago, that I really have no lasting impression of them. They look to be efficient but are 3-ways. The rear tweeter is switchable. They seem to be fairly well thought of. I will not be able to audition the speakers. The target room is a small office, 11'x13'x9'.
Click here for specs
Any thoughts on how the Type D might match up with the tubelets or comments on the character of their sound?
Others to consider (used <$300)?
Thanks,
Craig
Post edited by vcwatkins on
  • organ
    organ Posts: 4,969
    edited May 2012
    Why not bring the clone to his home and test it out. The Type D is 8 ohms / 90db sensitivity. If the impedance doesn't dip too low, it should be very tube friendly. Doesn't matter if it's three way or not. The most sensitive speakers I owned were 3-way at 104db sensitivity. No problem with a 3w/ch amp.
  • vcwatkins
    edited May 2012
    Not able to audition or match up with the amp. It would be a meet-half-way trade sort of thing.
  • organ
    organ Posts: 4,969
    edited May 2012
    That's always tough. Hopefully someone here have had experience with that combo.
  • erniejade
    erniejade Posts: 6,321
    edited May 2012
    1st $300 for snell D is a great deal! That said, they are NOT efficient. 89 db 13 watt tube will not give it enough juice in my opinion. If you listen to it quietly, then you shoud be ok but, if you want any kind of volume, the 13 watts will run out of steam quick.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2012
    I was thinking the same thing erniejade. Those Snells wont open up with that amp. Although 13 watts of Tube power is nothing to sneeze at, 89db speakers are.
    I also do not like titanium or hardened tweeters with Tubes. I prefer Silk or trilam types by a long way.
  • vcwatkins
    edited May 2012
    Gotcha. Many thanks for the advice. Opinions on good alternatives much appreciated.
    Craig
  • CSM41
    CSM41 Posts: 55
    edited May 2012
    Peter Snell made some fantastic speakers and those Type D's fall in that category. They do however, like power to sound their best.
    #1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
    #2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub
