putting a rack together need help
boston1450
boston1450 Posts: 7,758
edited May 2012 in 2 Channel Audio
if i put 2 marantz stereos and a tape player in a rack...is it possible to use 1 set of speakers...i went to radio shack today to see if they had a device/converter box that i could put both stereo speakers out too unit...with a selector so i could use one set of speakers vs 2 sets....can this be done....on top of the rack i would like to put a turntable on it also which shouldnt be a problem...id like to try to keep it clutter free of too many speakers in this den...any thoughts....thanx
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
  • decal
    decal Posts: 3,205
    edited May 2012
    Can you be a little more specific, what exactly do you mean by two stereos?
    edited May 2012
    He wants to be able to have two different Marantz receivers hooked up to the same pair of speakers.
    Yes! There are some switcher boxes that can do that, but I doubt you can find one at a Ratshack, because the switcher has to be able to completely isolate the two amps from each other. Off hand, I know I've seen some boxes that do this but can't quite recall the manufacturer at the moment, so .....later?
    This would work but I can't attest to its quality?
    http://www.amazon.com/Niles-Audio-DPS-1/dp/B00006HOFR/ref=sr_1_70?s=electronics&ie=UTF8&qid=1331750648&sr=1-70&tag=5336653703-20
    cnh
  • boston1450
    edited May 2012
    YES cnh you got it.....i want to put them in the same rack together. 2252-2230 and NOT use both at same time but be able to switch over to desired stereo. without needing two sets of speakers...been busy working today. i will look later on to see what might be available. thanx all
    Randy-Maine
    by David WMG
  • boston1450
    edited May 2012
    radio shack did have one for multiple speakers.....i thought of reversing it to multiple stereos. but wasnt sure it would work.....like i said only one would be on. just dont want 2 sets in room as its smaller room. randy
    Randy-Maine
    by David WMG
