Polk Audio RTi A9'S Does Polk Recommend Bi-Wiring or Bi-Amping?
AVTONY2510
AVTONY2510 Posts: 31
edited May 2012 in Speakers
Also how many Watts Per. Channel Amplifier does Polk Audio Recommend
for Maximum Performance?
Post edited by AVTONY2510 on
    VR3 Posts: 28,782
    edited May 2012
    500 watts is preferred..
    As far as biwire/biamp, etc - preference...
    Realistically bi-wiring versus a single wire with upgraded jumpers is negligible differences. Personally for I like having a dedicated wire run (although it connects to the same place on the amp) for each hook up.
    Technically bi-amping is useless unless you are filtering the signal before it gets to the amplifier... otherwise the amplifier is still amplifying a 20-20 signal versus a limited frequency signal.
    My suggestion is try to seek out a nice high current clean amplifier... somewhere from 100-500 watts and have at it! :)
  • AVTONY2510
    edited May 2012
    HEY VR3, so are you saying just hook them up the regular way with the jumpers on?
    VR3 Posts: 28,782
    edited May 2012
    Sure, I would replace the jumpers with a heavy guage wire though
  • Upstatemax
    Upstatemax Posts: 2,685
    edited May 2012
    Signal ultra bi-wire speaker cables are a great option at a very good price.
    If you want those A9's to sing, look for a good high current amp in the 200-500wpc range. I'm a huge fan of Parasound myself.
  • jbooker82
    jbooker82 Posts: 1,627
    edited May 2012
    I like Single Bi Wire cables as well. Single Bi Wire cables have one set of bananas on the amp / reciever end and 2 sets of bananas on the speaker end. You then remove the jumpers and plug all 4 in to the speaker.
    I use Audio Quest Type 8 single bi wires.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Geoff4rfc
    Geoff4rfc Posts: 2,474
    edited May 2012
    Heck yeah to the bi-wire AND upgraded jumper. I'm using both, here's a couple of examples.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • AVTONY2510
    edited May 2012
    Where can i purchase signal ultra bi-wire cables?
  • Upstatemax
    edited May 2012
    AVTONY2510 wrote: »
    http://signalcable.com/products.html
    If you mention you're a club Polk member you get a bit of a discount as well.
