Multiple Disc CD Player Advice
RocketOCannon
RocketOCannon Posts: 86
edited May 2012 in Electronics
I am going to be , buying an Oppo 95 for my main listening, Blue Ray SACD etc.
However, this is a single disc player. I would like to have something in addition that can play multiple CD's during a party, hanging around etc...more casual listening without having to be bothered with changing a disc all the time.
Any thoughts on this?
Recommendations on a solid multi disc player?
HOME THEATER 5.1
JVC DLARS56U
92" SI Black Diamond 1.4 16:9
NAD M25 MC Power Amp
Marantz AV7005 Pre Amp
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
LSIM 707 (2 Channel Sessions)
McIntosh MC312
McIntosh C49 Preamp
Marantz SA8005 SACD/CD Player
79' Pioneer SX-1080
Furman Elite 15 PC
SolidSteele HF-4 series rack
REL Carbon Special Purple Label
(Building system out currently)
(Use Quobuz almost exclusively - CD/SACD Part time)
OUTDOOR DECK
NAD C 375BEE DAQ
PSB CS 1000 Speakers
Sonos
Signal Cable - Ultra Single (Banana), Magic Power Cord, Dig Power, Vid Power.
RTi T3-V+, SONOS, Furman Power Conditioner
Post edited by RocketOCannon on
    txcoastal1 Posts: 13,519
    edited May 2012
    Do you rip your CD's to a PC?... Streaming using a squeeze box or sonos an easy way to go...run a mix of all your fav's or a good stream station
    edited May 2012
    txcoastal1 wrote: »
    Yep, can't beat those 2 devices with a stick for parties. I'd encourage anyone to take a serious look at either.
  • deronb1
    deronb1 Posts: 5,021
    edited May 2012
    I have had great luck with Sony carosel players. They are reliable, have a decent sound and are very reasonable. I found a 5 disc SACD changer for 50 bucks on ebay. Works like a charm.
  • rooftop59
    rooftop59 Posts: 8,120
    edited May 2012
    If you are set on a cd changer the Sony SCD-CE595 was great for me for quite some time. Not the fastest changer, but you will have to fork out the bucks for one that is. But it sounded pretty darn good for so cheap and also played sacds. I got more than my moneys worth out of that sucker. But I replaced it with a used squeezebox classic, and have never looked back. I listen to stuff that I haven't listened to in years because it's so easy to access. So I would also highly recommend looking into a streamer such as that.
    Game Room 5.1.4:
    Bedroom 2.1
  • Syndil
    Syndil Posts: 1,582
    edited May 2012
    Reported
  • Jer.War
    Jer.War Posts: 180
    edited May 2012
    I used to use a slightly modded denon 5 disc changer which sounded quite good.
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited May 2012
    the same as Deronib1 I also have a Sony 5-disc carosel which I got at Good Will for $15 w/ remote and it was really clean.I also have a dock w/ i-pod and that's like 4 days of music nonstop right there. Also depending on your avr you could h/u to i-net radio which basically commercial free and can tune in to specific groups ie; The Greatful Dead gd.net and on ......
  • decal
    decal Posts: 3,205
    edited May 2012
    If you really want a party machine get a Sony 300 disc jukebox like this one. . Hit shuffle play and listen for days on end. It will do what you want and store your discs in one box (you can pack your cd jewel cases in an out of sight location). It won't be the last word in fidelity but it will work just fine for what you have specified.
  • kidglove13
    kidglove13 Posts: 207
    edited May 2012
    I recently picked up an Onkyo DV-CP702 6 disc changer for around $30
    It claims to be a DVD player but it is much better as a CD player from what I have found over the last few months or so of using it
    It has dual Burr Brown DAC's in it which is why I picked it up for a CDP, I cant remember which ones, but it does a nice job, for me that is
    edited May 2012
    Lots of options out there. But they're mostly older because fewer and fewer manufacturers are making changers these days. I've had the Sony and I still have a JVC from the late 90s that "refuses" to die (those old JVCs had some heavy duty long lasting lasers in there)..
    Good luck!
    cnh
  • Syndil
    Syndil Posts: 1,582
    edited May 2012
    I agree that the Squeezebox is the way to go, but the best solution for a multi-changer I have seen (and still kind of want) is the Denon DCM-5000/5001. The 5000 is a 100 CD, programmable dual-transport CD/HDCD changer with crossfade capability. The 5001 units are 100 disc slaves to the 5000. The slaves are also dual-transport so there is never a delay between tracks regardless of which disc is playing next. These units cost about $1800 new and are now very hard to find, but they are very high quality. Check reviews online and you will find people comparing them favorably to players from Meridian and Linn. I've long been a fan of Denon's digital sources myself. Don't really care for much else they do, but their CD players are special IMO.
