Daylilly question?
obieone
obieone Posts: 5,077
edited May 2012 in The Clubhouse
Disclaimer: I don't know jack about plants.
I don't know if this plant is getting too much water, or not enough?
I started the season on my electronic timer at 20 minutes, twice a day. As the plant bloomed more, I upped it to 30 minutes, twice a day,
Then they started to die off, so I upped it again to 45 minutes twice a day, but no luck. It's still withering.
I used to be able to tell(I think), when the plant had enough water, because of the droplets forming on the leaves, but now, nothing?
Need some help:cry:
TIA
Post edited by obieone on
  • bmbguy
    bmbguy Posts: 416
    edited May 2012
    My wife says no flowers bloom continuously. And with as much water as you're giving it, you're running the risk of rotting the bulbs so they won't come back up next year. Let the plant do its thing.
  • obieone
    edited May 2012
    10-4 thanks
    mhardy6647 Posts: 35,522
    edited May 2012
    Daylilies, once established, will thrive even when it is very dry. They don't need much water.
    edited May 2012
    Yep, ^^^^^
    Only in a drought should you even water them. I never water mine and they do very well. Another thing to look for are bugs. Take a shovel full of dirt out next to the plants and see if there's any nasties, like grubs, in your flower bed.
  • gdb
    gdb Posts: 6,012
    edited May 2012
    Heck, I have a tough time Killing those things, when they come up where they're not wanted !
    edited May 2012
    gdb wrote: »
    Well then, you just found your answer.....water the crap out of them. LOL !!
  • gdb
    gdb Posts: 6,012
    edited May 2012
    I do !!! With some Round-up mixed in:lol: for flavor !
