amplifiers w/ volume controls
leftwinger57
leftwinger57 Posts: 2,917
edited May 2012 in Electronics
I noticed on some brands of amplifiers both new and vintage have volume controls. You still need a pre-amp so what real purpose besides maybe that you could dial in your balance better then let the pre and your source gear do the rest. Macs,Crown and some others have done this for years on both ss and tube amps.I don't know if I answered my own question but if there if a more specific reason I'd like to find out.
  • drumminman
    drumminman Posts: 3,396
    edited May 2012
    If you're using more than one amp in your system (as in passive biamping) a volume control on the power amp allows equalizing the output of the amps. Especially important if you're using one brand for the low end and another for the high end.
    Once you've adjusted the amp outputs so they're equal, when you adjust the volume on the preamp it maintains this balance as you increase or decrease it.
  • leftwinger57
    edited May 2012
    Thank you.There had to be a decent explanation for this.
    mhardy6647 Posts: 34,916
    edited May 2012
    It's not a given that one needs a pre-amplifier.
  • leftwinger57
    edited May 2012
    I guess that would be true w/ an integrated type amp. But a pure power amp ,how is that achieved.
    edited May 2012
    If the power amp has adequate gain, and there's an attenuator on the source (as found,e.g., many CD players and on older tuners),there may be no need for any form of preamp, even a "passive" one.
    In my case, I have a passive autoformer volume control and a source selector switch between my source components and my power amplifier. No more, no less.
    txcoastal1 Posts: 13,499
    edited May 2012
    What Mr.H said...I have connected my W4S dac and Sonos directly to the amp and used Dac's and my Sonos ZP-90 volumn control
