Adcom GFA-555ii
audiocr381ve
audiocr381ve Posts: 2,588
edited June 2012 in 2 Channel Audio
Is one worth $300 is great condition? Would it be a step up from my Parasound HCA-750a or a lateral move?
Post edited by audiocr381ve on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2012
    $300 -$350 is about the average for one in good condition. Never heard the HCA-750 but I'd take the adcom over that smaller parasound. For a couple hundred more I'd go after a HCA-1500 or something similar.
  • audiocr381ve
    edited May 2012
    Thanks Leroy, any other thoughts on this? I'm driving a pair of 4 ohm speakers.
    edited May 2012
    The Adcom will drive a 4 ohm load all day long and not break a sweat. But I agree with Leroy. Worth about 300. And more neutral sounding than a Parasound. Parasounds are generally, "warmer". This is really a call on what kind of sound you prefer.
    Plus Adcoms are very picky about the pre you match them with. They really need a "good" pre to shine!
    cnh
  • audiocr381ve
    edited May 2012
    I'll actually be using a Pass DCB1 buffer as a preamp. I wonder how that would work.
    My speakers are pretty efficient (I think) at 88db. Hmmm...what to do..
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2012
    the Adcom is my first foray into seperates and I couldn't be happier. I got mine from Audio Classics w/ shipping included for an even $300. The thing came slippery clean does not get even the slightest bit warm after running all day, and from what I hear and have been told it can push around and speaker load that this forum deals with. They are all over e-bay and do average 3bills just look for the one in best shape.Here you will get differing opinions but since I only know of one and it's the the one your after go for it.
  • kidglove13
    kidglove13 Posts: 207
    edited June 2012
    I have been running the smaller 545 for a long time
    And that gives me all the power I need for my SDA's
    So the 555 can easily power pretty much anything with ease and $300 is about average rate
    As others have said they are a little picky about pre's
    I run a small tube preamp and I have been pretty happy with that set up
    I do not know much about buffers
  • sda2mike
    sda2mike Posts: 3,131
    edited June 2012
    i have a 555...it's a hook it up and forget it's there component..i'm sure you know - get good cables
  • chandler9a
    chandler9a Posts: 887
    edited June 2012
    I also have a 555 original. Love it but starting to think about moving up the chain a bit. Something that would match nicely with my GFP-750. Thinking about B&K but I'm sure there are a good number of choices out there. Hard to beat the GFA-555 for the price.
  • hochpt21
    hochpt21 Posts: 5,423
    edited June 2012
    chandler9a wrote: »
    Your thinking about the B & K and I'm thinking about the GFP-750. Maybe we should just be roomates? Ok, maybe that was weird. :cool:
    heiney9 Posts: 25,557
    edited June 2012
    88dB is not that efficient. The 555 will run them fine. You could look at something a little higher the chain too.
  • audiocr381ve
    edited June 2012
    heiney9 wrote: »
    Yea, the shipped has sailed on this thread.
    I'm actually getting a Pass F5 DIY amp from the same gentlemen I bought my DCB1 from. Should be a treat :cheesygrin:
  • FTGV
    FTGV Posts: 3,650
    edited June 2012
    d.
    Not likely to be a good marriage since the F5 has low gain so in most systems will need to used with a preamp having more than unity gain.
    edited June 2012
    FTGV wrote: »
    Have to agree plus 88dB speakers with crossovers isn't the best match either, better than some other First Watt gear however. First Watt gear with a couple model exceptions aren't really made to drive conventional speakrs.
    You should seriously look at the Aleph 30 on Audiogon if it's still FS, offer $900. You can thank me later :lol:
  • FTGV
    FTGV Posts: 3,650
    edited June 2012
    A multi way speaker should'nt present a problem for the F5 but it will in all likelihood require some voltage gain preceeding it if you want to have any sort of reasonable output with speakers of average sensitivity.
  • audiocr381ve
    edited June 2012
    FTGV wrote: »
    It's actually a F5T, I don't know if that matters. But before my DCB1 shipped the gentlemen who built it hooked it up to his F5T and said they had great synergy. I guess we'll see!
    Btw, he's letting me audition at no cost to me.
    edited June 2012
    Can't hardly go wrong there.
  • FTGV
    FTGV Posts: 3,650
    edited June 2012
    Synergy no doubt,enough gain maybe not.But since you get to test drive first you'll be able to determine for certain.
  • audiocr381ve
    edited June 2012
    Exactly. The DCB1 is a great piece by the way, I hope the F5 compliments it. I'm having a ton of fun adding a little DIY to the system.
    edited June 2012
    If it all works together and the clone is actually a decent one, you should be ready to **** your flat hat!
  • audiocr381ve
    edited June 2012
    heiney9 wrote: »
    Hehehe, I certainly hope I do:cheesygrin:
