RTA 12 pcb's
soundfreak1
Are the pcb in the rta 12 the same boards used in the rta 12c's? May be doing the mod to my c's but do have a pair of rta 12 pcb's ( as parts, not in cabs) Can the rta12 pcb be built as c's by simply changing the cap to the 12c values may have to alter the circut paths butare the naked pcb's the same? Thanks. Also what the coils?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
If they're 12's, the very 1st ones of the RTA line, I don't think they're compatible with B's or C's. The latter have very different Xovers, which made the two 6.5 inch drivers in each cabinet operate in different parts of the frequency range.
Related to this is the fact that RTA 12B's and C's are mirror imaged - if set up with the speakers on the wrong side (i.e. the right on the left and vice versa) the soundstage totally collapses. When they're set up properly the music doesn't sound like it's even coming from the speakers, it's just projected into the room with a sweet front to back depth and side to side width.
Modded 12C's have some of the best imaging I've heard outside of SDA's"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Was afraid of that. Oh well , hoped i could use them if the boards were the same.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
