HT system popping breaker box?
Dabutcher
Dabutcher Posts: 2,604
edited May 2012 in Electronics
Never had this issue before. Set up is in lower level finished basement. Fifteen amp modular breaker has popped twice. So I figured I better leave it alone for now. Was listening to The Current. Radio station w only one two channel amp while I played Gran Turismo on PS3. My only guess is to get a new fifteen amp breaker and install it? We did get 2 1/2 inches of rain in the last twenty four hours? Carpet is dry. As always, thanks for any and all help. Darryl
Post edited by Dabutcher on
  • Dabutcher
    edited May 2012
    Monster power conditioner shows volts at between 117 & 119
  • dkg999
    dkg999 Posts: 5,647
    edited May 2012
    Circuit breakers do sometimes go bad. I would try a new breaker. If you have someone with the right electrical meter you could measure the load on the circuit. A bad outlet that is arcing can also cause the breaker to trip.
    DKG999
    tonyb Posts: 33,065
    edited May 2012
    Could be a bad breaker, but also, check what else is on that breaker. Washer and dryer.....A/C, can suck up the juice, then when you hit dynamic passages and your amp needs to kick it up a notch, the breaker trips. May need to plug the system into an area in the basement that doesn't have additional heavy loads on the line.
  • zane77
    zane77 Posts: 1,696
    edited May 2012
    I think with the XPA2 and 3 on a 15 amp breaker with the rest of your gear and any other items that run off this breaker you are overloading the circuit and causing the breaker to trip. I think you should try and distribute some of this load to some other circuit or run another 20 amp circuit for the amps.
    Two Channel
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2012
    I vote for a possibly bad breaker. I also think Zane has a very good idea. Separate the load some or add another 20amp circuit if you can.
  • Dabutcher
    edited May 2012
    Thanks for all the help. Replaced the breaker and for three hours now everything is fine. Darryl
    heiney9 Posts: 25,398
    edited May 2012
    zane77 wrote: »
    Those amps aren't even close to needing a seperate 20amp circuit, give me a break. They are standard run of the mill amps, nothing special as far as voltage or current draw. That doesn't mean a circuit isn't overloaded because of too many devices but it's not the amplifiers by themselves.
    Sounds like the new breaker solved your problem.
