First Legal HD DVD player
PolkThug
PolkThug Posts: 7,532
edited October 2003 in Electronics
Finally, we can unleash our DVD's with the Samsung DVD-HD931. I'm ordering mine tonight. (Do not order this if you don't have an HDCP compatible TV or you won't be able to go above 480p). Does anyone have experience with this DVD player? I am a little nervous about buying the first one that is out on the market. It will be sweet to watch Matrix again at 720p/1080i.
Post edited by PolkThug on
  • ken brydson
    ken brydson Posts: 9,003
    edited October 2003
    Where are you ordering from and what does it cost?
    I just found it online @ CC for $283.98 but the reviews are mixed.
    http://www.circuitcity.com/display_review.jsp?c=1&b=g&OID=78585&catoid=-8039
  • Ron-P
    Ron-P Posts: 8,520
    edited October 2003
    I believe the V Bravo D1 player has been out for quite awhile. Have you checked it out? It can be had for under $200 and there is quite a few threads on it over at AVS.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • PolkThug
    edited October 2003
    Ken, I am getting it from CC. It sounds like most of the people that complained about the Samsung probably didn't have an HDCP (high definition copyright protection) TV.
    Ron, I'll check that other one out too.
    I've always wondered why there were no HD DVD players, and it was all about copyright protection. Execs were worried that the DVD's could more easily be hooked up to computers. Hence HDCP, which I don't think the first generation HDTV's have. Which in turn, is probably why some of the people that bought the Samsung couldn't get 720/1080 out of it.
  • PhantomOG
    PhantomOG Posts: 2,409
    edited October 2003
    this isn't "true" hd though is it? these HD players have line doublers or whatever to reach these resolutions right?
    i'm always amazed at how much better my HD cable reception looks compared to my progressive scan DVD player. it would be nice to have "true" HD-DVD where the discs are actually recorded with 1080i/720p resolutions.
  • Ron-P
    Ron-P Posts: 8,520
    edited October 2003
    Correct. You can't get true HD from a non-HD source.
    If my Panny had DVI I'd get one, but the 200u does not and I'd need to order up a $150 transcoder box to do it. I figure I'll wait and see how the 500u fairs that is just getting released and in a year, possibly upgrade. Of couse by then, we may just have HD-DVD and if so, that will require yet another DVD player.
    Peace Out~:D
    If...
  • PhantomOG
    edited October 2003
    from what little i've read online about the current situation with HD-DVD, it doesn't look promising.
    from what I remember the industry is fighting over a standard and I think the longer they take the less chance of HD-DVD actually taking off. i'm afraid of it going the way of the "super" CD or whatever its called and be a small niche market which is a shame.
  • Ron-P
    Ron-P Posts: 8,520
    edited October 2003
    The blue-ray HD-DVD players are already out in Japan. I forget the details but I believe they streeted at about 2k. The disks are only single sided which is a down side right now. I can dig up more info.
    HD-DVD will be a small nitch market for a long time after it's introduction. Most of the GP will not care as most don't have HD-ready TV's. It will be expensive, there is not doubt. But, it will arrive.
    Peace Out~:D
    If...
  • PhantomOG
    edited October 2003
    that's crazy expensive... especially considering only a small number of titles will be available.
    i don't know, maybe it will take off. the "content" on dvd's is alot easier to grasp and appreciate. for example, next gen gaming consoles will probably need higher density discs than standard dvd's. maybe the game industry will drive improvements in video standards.
    does the blue-ray dvd players play standard dvd's? i assume it would.
  • Ron-P
    Ron-P Posts: 8,520
    edited October 2003
    I believe it is backwards compatable, but I'm not 100% sure.
    As far as expensive, do you remember how much progressive scan DVD players were when they first streeted? They were about $1,600 or so. By the time it hits here, I'm betting they'll be about that price and drop quickly. Kinda like what we saw with HD-VHS.
    Peace Out~:D
    If...
  • scottvamp
    scottvamp Posts: 3,277
    edited October 2003
    Many of the new projectors and tv's have the DVI connection which is claiming to give HD quality by up converting the signal to 720 or 1080 with the new DVI DVD players. No one with these DVI setups have been impressed at all. If they were getting true HD quality on these setups believe me they would be blown away. My Sanyo projector does not have DVI. It just now hitting the market in the last year.
    I have never heard this issue as a copy writing problem. This all capable throught the DVI connection which is computer based connection allowing for the upconverting as I said. I have read a few threads on this and only one person had the setup and was able to toggel back and forth between 480p and the "HD" and there were no or very little differences in the picture quality. If the DVD is not recorded in HD than your not getting true HD plain and simple.
    Polkthug what monitor are you using?
  • eclypse
    eclypse Posts: 595
    edited October 2003
    Its not a true HD DVD play since it upconverts the vid with software.. I've had that player with a Samsung 61" DLP and didnt like the picture. I've just returned it the other day and i should have me a quality DVD player (Denon 2900) Friday evening. I'll report back ASAP on the difference in PQ..
    BTW.. If you dont have a true Digital HDTV dont bother with the samsung 931 player since you wont notice any difference in PQ since your TV will be converting it back to Analog.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited October 2003
    Peace Out~:D
    It would be a still-born if it wasn't.
    SVS
  • Ron-P
    Ron-P Posts: 8,520
    edited October 2003
    Not in my book. When the HD-DVD players street here in the states I will jump on board even if they are not backward compatible.
    The only reason I have not bought into D-VHS is becase HD-DVD is close, if it wasn't I'd have my D-VHS machine already.
    Peace Out~:D
    If...
  • scottvamp
    edited October 2003
    I would love to have a d-vhs player to see it on my FP but just not into it having to buy the player and the little software out.
    Eclypse, thanks for chimming in - that is what I have heard all around also. I have had the Denon 2800 for awhile now and it is built like a tank. It has done an incredable job with everything I have thrown at it.
  • bikezappa
    bikezappa Posts: 2,463
    edited October 2003
    I purchased a Bravo DVD player with the DVI output and connected it to my front projection NEC 1000 which has a DVI input. I had all the goodies, new intruction CD from Bravo, the hot settings for the NEC 1000. No or very small difference in picture from 5 people all looking and comparing.
    I sent the Bravo back.
    Good luck
  • scottvamp
    edited October 2003
    Sorry to bum ya out PolkThug that has not commented yet. Nice little Samsung promo though.
    Thanks for another confirmation bikezappa!!!!!!
    I hate being right most of the time.........;)
  • brettw22
    brettw22 Posts: 7,623
    edited October 2003
    Thank God that hasn't happened then...... :cool:
  • Rotarydude
    Rotarydude Posts: 40
    edited October 2003
    The one to look for is the the Denon 5900 when the DVI is activiated. This is truly going to whip those "so-call" DVI players.
    Family room:
    2xLSi25, 1xLSiC, 4xLSiFX, SVS 20-39PC+, PT-52DL52, TS160, DTR 9.1, DVR985, DVL-700, CDP-C910, Panamax 5500 connected by Canare (4S11 w/Vampire and L-5CFB)
    Masterbed room:
    2xAR312-HO, 1xAR4C, 2xAR15, NHT Subone, WT-46805, SR-HD500, M-VR900, Denon 1600, Monster HTS-3500 connected by Monster Cables
    Waiting:
    Denon 5900, Denon 2200, and a 7 Channel 4ohm stable amp!
  • PolkThug
    edited October 2003
    After doing more reading about Samsung's "upconverting", I canceled my CC order. I thought it would be true HD, but it's not. :( What a let down.....
    I just ended up getting a Panasonic DVD-35 player. My TV is a Hitachi 57S700.
    Oh well, the 480p from the Panasonic looks pretty good. You can really see the pock marks on Morpheus' face in Matrix Reloaded. :D
  • begbie
    begbie Posts: 630
    edited October 2003
    Good call !
    I've seen some of the ads that lead you to believe it's true HD but when i went for a demo.......Heck !? My HD-television can do the same upconverting and even better !
    If anything, this Samung product and its dvi capability is just another step of Hollywood not letting you copy their HD stuff !
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Polk fx500i -side surrounds
    Polk rc60i -rear surrounds
    Onkyo TX-NR 1009 (9.2) receiver
    Velodyne cht12
    Polk psw111
