Recapping my Adcom 545
kidglove13
kidglove13 Posts: 207
edited February 2014 in Electronics
Looking for a little help on recapping my Adcom 545.
Is there any good resources or write ups for recapping these amps?
What caps would I use to recap?
Upgrades etc.?
Thank you
Post edited by kidglove13 on
  • sda2mike
    sda2mike Posts: 3,131
    edited May 2012
    precd recapped his gfa 555...you might want to shoot him a pm..
    heiney9 Posts: 25,580
    edited May 2012
    check www.diyaudio.com
    all sorts of adcom diy info.
  • sonichermit
    sonichermit Posts: 1
    I am brand new to this forum and have a few questions regarding recapping my Adcom GFA 545. I started work on it and so far havhave removed one of the large Towa 10,000uf 63V cap. I need to know how to tell which of the two solder lugs on the top of the cap is negative and which is positive. One lug has a bit of a stamped knurl pattern on it and one is just plain. This is actually more of a job then sometimes portrayed. There is difficulty in removing these large caps due to the claps. I am replacing with Nichicon military grade caps with screw on terminals. That decision was made because I wanted caps of the same basic size and diameter. Hope it was not a bad choice. It will require some changes in how the buss rods are attached. Concerning the other caps on the pc boards it appears as though I will need to unscrew the entire heat sink assembly along with the pc boards to get under them and desolder the 47 uf and 4.7 uf caps. Any tips or information in this regard will be a big help. Certainly do not want to blow up the unit by incorrect connections to those large caps.
    SCompRacer Posts: 9,152
    On Snap-In and Lug Terminal type capacitors, the knurled rivet indicates the negative terminal. Negative terminal can also be indicated with color band or arrows on capacitor body.
  • skrol
    skrol Posts: 3,480
    For electrolytic caps in the signal path, I can recommend the Nichicon Fine Gold (FG) and Nichicon MUSE (KZ). My little Parasound amp and pre-amp sound sooo much better.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
