Parasound HAlo A23 Vs Emotiva UPA-1
Pinktulip7
Pinktulip7 Posts: 249
edited May 2012 in Electronics
I am using Emotiva UPA-1 for Center Ch. but realy wants to upgrade to Parasound Halo A23...any suggestion?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
    pitdogg2 Posts: 26,971
    edited May 2012
    Pinktulip7 wrote: »
    Do it!!! what are you waiting for it's a no brainer....
  • Pinktulip7
    edited May 2012
    but how it will be sound?I will using it as a Monoblock to power up Polk Center Channel..
    heiney9 Posts: 25,421
    edited May 2012
    Pinktulip7 wrote: »
    Buy it and find out
  • Pinktulip7
    edited May 2012
    hugh#?
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2012
    The only person who can decide if you like the sound is you.
    That being said normally Parasound tends to have a warmer sound signature than Emo. I have used both and perfer the Parasound.
    Also it would match your other amp which would be a better fit than the Emo. Keeping everything the same for the gain levels etc.
  • Pinktulip7
    edited May 2012
    cool........:cheesygrin:
    edited May 2012
    In all seriousness, it probably won't make any difference using it for a center channel in an HT system, which is not a super critical area.
  • Pinktulip7
    edited May 2012
    so don't get it....:sad:
    edited May 2012
    Pinktulip7 wrote: »
    Do whatever you want? In fact I'm not even sure what this thread is about since this is all you posted originally
  • chumlie
    chumlie Posts: 8,658
    edited May 2012
    Buy it and use for your fxi a6 or the a3's if you don't like it in the center.
