Dumb question, but i will ask anyway
kidglove13
kidglove13 Posts: 207
edited May 2012 in Vintage Speakers
When I remove the drivers from my 1B's for magnet epoxy and dynamat can I just put them face down on my table?
Will this hurt the surround/face of the driver?
It might be a dumb question but I dont want to break any thing
Post edited by kidglove13 on
  • codyc1ark
    codyc1ark Posts: 2,532
    edited May 2012
    I vote fine. Good luck on the upgrade!
  • headrott
    headrott Posts: 5,496
    edited May 2012
    They will be fine. It would be even better if you put them on something soft (like a towel or carpet). You will really like the dynamat mod.
  • decal
    decal Posts: 3,205
    edited May 2012
    Here's my dumb answer. If you're worried about, don't do it !!!!
  • falconcry72
    falconcry72 Posts: 3,580
    edited May 2012
    There are no dumb questions, only dumb people!
    I vote for soft, CLEAN,
  • falconcry72
    edited May 2012
    ...surface.
    I just screwed that post up. That was dumb of me..
  • brgman
    brgman Posts: 2,859
    edited May 2012
    I think they like getting done face down.
    just sayin'
    I’M OFFENDED!!!!
  • falconcry72
    edited May 2012
    brgman wrote: »
    just sayin'
    Lol!
  • kidglove13
    edited May 2012
    Alright, Alright I get it.
    It did not take to long for this post to go the other side LOL!
    nooshinjohn Posts: 25,464
    edited May 2012
    Anything but the missionary position and you should be fine.
  • halo71
    halo71 Posts: 4,606
    edited May 2012
    69 'em! Don't forget the pictures though. :cool:
    --Gary--
  • gdb
    gdb Posts: 6,012
    edited May 2012
    My preference is clearly shown below.:wink:
    edited May 2012
    Dude looks like a lady!:cheesygrin:
