One MW 6511
Cosmic_American
Need a replacement for my CRS+ left channel. Probably going to go ahead and order a driver from polk, but thought I'd check for an original in the forums.
2 channel:
SDA CRS+
Harman Kardon HK 3490
Music Hall mmf-2.2
SDA CRS+
Music Hall mmf-2.2
Post edited by Cosmic_American on
I use a replacement I got from Polk, and it is fine, but make sure you CAREFULLY cut out the holes around where the screws will go through. Any rubber touching will pull the rubber surround away.
I just looked on ebay and there is only 6510's and 6503's on there.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
