Acoustic Panel Location for PowerPort Speakers
mufsoman
mufsoman Posts: 632
edited May 2012 in Speakers
Finally made the investment of some acoustic panels for the theater area. Planning on putting a panel behind each tower and center channel (along with several other strategic locations in the room) as recommended. However, considering that the Rti12's and CSiA6 have the Polk Powerport features on the back, does it really make sense to locate panels behind the speaker vs. somewhere off to both sides? Is the positioning of panels behind a speaker only good when the speaker is direct ported through the back? Thanks
Parasound HCA-2003A & 2205A
Front: Rti12's
Center: Csi A6
Side surrounds: Polk Rti A1's
Atmos: Mirage Nanosats
APC H15
Power cords by Pepster, Morrow MA4 IC's, AQ Midnight, AQ Chocolate HDMI's[/SIZE]
The rest is TBD.
Post edited by mufsoman on
  • Face
    Face Posts: 14,340
    edited May 2012
    You're over thinking things... ;)
  • mufsoman
    mufsoman Posts: 632
    edited May 2012
    Its the curse of being an engineer....
    Front: Rti12's
    Center: Csi A6
    APC H15
    The rest is TBD.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2012
    You will still benefit from the acoustic panels in either case.
    The biggest improvement I made besides better hardware was the acoustic panels behind the speakers and at the first reflection points on the walls to the side of the speakers. There is a neat video on youtube by Martin Logan explaining the easiest way to find the first reflection point.
