new polk MW6510 replacement driver (RD6519-1)
11tsteve
stan asked me to post some pics of the new driver for my RTA11ts when i received it from Polk.... so, here we are.
dropped it in today and so far, so good. i haven't had a huge block of time to listen, but first impressions are good. it isn't sounding like a car horn in the midst of everything else going on...:cheesygrin:
the MW6510 is on the left in the pics with both drivers.
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
Keces DA-131 mk.II
Be careful with the rubber surround.If you don't carefully trim at the holes and tighten a screw down it can and will tearMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
thank you. i was not aware of this and have now learned something new today.Polk Lsi9
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Perhaps Polk CS should start including a note regarding trimming the surround before installing.Stan
Main 2ch:
HT:
Other stuff:
Ditto on the trimming !!!!!!!! I was warned and I thought I had done enough but I had not. The surround at one mounting point was becoming deformed because of the pressure from the mounting screw. I work at a hospital and obtained several of the small size 15 scalpels with these I was successful in getting the rubber trimmed up. The silicone rubber is very tough and it took a ultra sharp blade to trim it.Radio Station W7ITC
transmaster wrote: »The silicone rubber is very tough and it took a ultra sharp blade to trim it.
For the record, it's butyl rubber.Political Correctness'.........defined
