Bracket RM7 Speaker
brickpit
brickpit Posts: 2
edited May 2012 in Speakers
I am looking for a bracket for Center Channel RM7 speaker. I lost the one that came with it. Can anyone point me to a link or a model# of brand that would work?
Post edited by brickpit on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited May 2012
    Hello BP,
    Welcome to Polk's forum. You should be able to find all the RM7 accessories from Polk's CS department at 1-800-377-7655 or via email at polkcs@polkaudio.com. They'll be available Monday after 9:00 a.m. eastern. You can also consider the OmniMount 10.0 series of brackets, Polk uses a 1/4" opening with a #20 thread.
    Regards, Ken
  • brickpit
    brickpit Posts: 2
    edited May 2012
    Hello BP,
    Regards, Ken
    Thanks Ken. Would you be able to point me to a link for exact OmniMount that would work for the center channel speaker? I tried looking on Amazon but most seem to be for tvs or bookshelf\side speakers. (If you can't tell by now, I'm a little bit of a novice\newbie :redface:). Would prefer trying to find SOMETHING outside of Polk 800# because guessing they jack up prices and shipping costs, and just prefer ordering things online too.
  • [Deleted User]
    edited May 2012
    Hello,
    Actually Polk gives Club Polk members (which you are) a 20% reduction and free shipping on all the parts they sell. The original RM brackets and center cradles are very reasonably priced. As far as the OmniMount brackets I don't believe Polk sells those directly. Let me look at OmniMount's site.
    Cheers, Ken
  • [Deleted User]
    edited May 2012
    Hello,
    If you want a wall mount bracket that lets you aim the speaker the OmniMount 10.0 W/C bracket should be the choice. The Polk supplied wall mount bracket is a non-moveable bracket that can be ordered from Polk CS.
    Cheers, Ken
