Question on dynamated 15" passive radiators
fjross
fjross Posts: 183
edited May 2012 in Vintage Speakers
Would anyone happen to have an pic on how you dynamatted the PR's. I noticed there are raised ribs on the spokes that come out from the center. Is this were you applied the dynamat?
Thanks Dave
Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's
Post edited by fjross on
    EndersShadow Posts: 17,722
    edited May 2012
    F1nut Posts: 51,996
    edited May 2012
    fjross wrote: »
    Thanks Dave
    Yes, the spokes and on the PR's, do the round end bell piece as well.
  • fjross
    fjross Posts: 183
    edited May 2012
    Thanks for the replies. I just got done with finishing up 1 speaker with the Black hole 5 (4" strips) as well as a set of Larry's rings and the Cardas binding post upgrade. I'm looking forward to audition the800va dreadnaught for the first time with my monoblocks. Does anybody have a trick for wiping down the sticky material on the drivers?
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
  • drumminman
    drumminman Posts: 3,396
    edited May 2012
    fjross wrote: »
    If you mean the MW cones, people here tend to use Windex to clean them.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited May 2012
    I'll try to find pics of mine when I get home. The drivers are much simpler to dynamat effective as they are smaller and have the added benefit of the magnet /top plate/ pole peice for some stiffening/damping effect on their frames. I found when dynamatting the passive frames, (especially the 15's) I needed multiple layers to satisfactorily dampen the frames. I judged this by tapping the frame with the end of my finger (no contact with my nail) and listening for any ringing in the frame. I actually ended up using 3 layers on the ribs of the 15's a large more complete layer first and then smaller peices on top of those with a layer underneath on the cone side as well, and 2 layers on the back flat area. This may have been overkill as once mounted with gaskets, more damping is applied to the frame, but i found it easier than mounting, listening, removing and redoing.
    F1nut Posts: 51,996
    edited May 2012
    As mentioned, Windex works very well. Spray it on a lint free cloth and wipe in a circular motion.
  • transmaster
    transmaster Posts: 424
    edited May 2012
    A great source for Dynamat is Summit Racing, and Jegg's. I have delt with both and they are good to go, take your pick. Below is a door speaker kit which is what you want.
    [http://www.summitracing.com/parts/DYC-10415/
    http://www.jegs.com/i/Dynamat/327/10415/10002/-1[url][/url]
    Radio Station W7ITC
