Bookshelf speakers to pair with CS245i?
Jimbo18
Jimbo18 Posts: 2,351
edited May 2012 in Vintage Speakers
My first post, so please forgive a question that is obvious to others or has been covered in the past.
I have a very limited budget. I recently bought a used CS245i as an upgrade from an even older Polk center channel that I am using in the bedroom as part of a 3.0 setup. The bookshelf speakers I have it paired with are old Monitor 2's, I think, but the identification plates are long gone from them and I bought those used also.
I just wondered what bookshelf speakers would complement the CS245i best (which sounds great to me compared to the CS-150 which it replaced). The center seems to overpower the side speakers. Not looking for anything too big since it's just the bedroom. Any advice would be appreciated.
Off topic - my setup downstairs is much better but is also using older speakers. Altec Lansing Santana speakers from 1975 (as fronts) and JBL Northridge center and rears pushed by a new Yamaha RX-V373 receiver. Again, I know it's low tech stuff but I just use it for TV and some movies.
Post edited by Jimbo18 on
