Really dumb question
JDOGG
JDOGG Posts: 433
Probably stupid but, how do you bi-wire.(sorry for such a dumb question).
Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable
Post edited by JDOGG on
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2003
    1. Remove the "shorting bar" from the speaker terminals.
    2. Connect 1 pair of speaker wires from the amp to the top 2 posts of the speaker, observing proper polarity. This is your mid/high feed.
    3. Connect a second pair of speaker wires from the amp (speaker "B" or from the same post as the first run if you don't have speaker "B" connections) to the bottom posts of the speaker, observing polarity. This is your woofer(s) feed.
    You're bi-wired!
  • JDOGG
    JDOGG Posts: 433
    edited October 2003
    Thanks alot man, that really helps me out.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • ziggy0809
    ziggy0809 Posts: 18
    edited October 2003
    A man who asks a question is dumb for 2 minutes.
    A man who never asks a question is dumb forever.
    No such thing as a dumb question!
    Cheers
    Zig
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2003
    Never a dumb question here....maybe asked previously, but never dumb.
  • eclypse
    eclypse Posts: 595
    edited October 2003
    Ok.. Then i got a dumber question. WTH is B Stock???? Man does that one bug the hell outa me. After looking for new equipment online i seen that alot and know its not what i want but i cant figure out what the hell it is.
    Sorry for bargin in on your thread but.. hehe. figured i'd make it a dumb question for all type thread hehe.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
    F1nut Posts: 51,682
    edited October 2003
    Simple, B stock is not A stock.
    It means it has a defect (cosmetic) from the factory, but performs flawlessly. It could be a dent or scratch, so you have to decide if you can live with a imperfection to save a few bucks.
  • eclypse
    eclypse Posts: 595
    edited October 2003
    THANKS for settin me straight. :)
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • 4_everyman
    4_everyman Posts: 50
    edited October 2003
    Cheers
    Zig
    I dunno 'bout that, Ziggy. I might be the only living exception to that statement. :D
    Rgds,
    --pete
