Revox A77 project
[Deleted User]
[Deleted User] Posts: 7,598
edited May 2012 in 2 Channel Audio
Hello,
I thought I'd share some photos of a classic Revox A77 deck that I've been working on. I've taken it completely apart and cleaned and polished everything I possibly can. All of the resistors and caps in the record/playback circuit have been replaced as well as PS caps and motor snubbing caps. I've replaced the internal wiring with Cardas balanced cable and added to the AC hum shielding. Both of the tape transport bearings are replaced. The last two photos are of the record/playback frequency response for each channel using SM911, each vertical division is 2dB and the frequency is across the bottom. Not bad for a 30+ year old deck.
Cheers, Ken
  • madmax
    madmax Posts: 12,434
    edited May 2012
    As always, NICE!
    Vinyl, the final frontier...
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2012
    As soon as I saw "Revox" I knew this was a Ken post. Awesome as always Ken.
  • [Deleted User]
    edited May 2012
    F1nut Posts: 51,953
    edited May 2012
    Nice work, Ken. How long did that job take?
  • [Deleted User]
    edited May 2012
    That one took about 9 months, on and off. I think the next one I'll try using good quality electrolytic caps instead of the film type. It takes so much effort to get them on the boards. But, I have some replacement transistors and a separate audio PS on hand to try. Plus I think I'll have the overall frame pieces powder coated to see how that looks.
    F1nut Posts: 51,953
    edited May 2012
    You can't rush good work.
  • organ
    organ Posts: 4,969
    edited May 2012
    Excellent work. You have great talent working in a cramped chassis like that. I bet it sounds superb.
  • [Deleted User]
    [Deleted User] Posts: 1,223
    edited May 2012
    Does the rebuild include a healthy dose of that "Baltimore Basement" air, I hear it has magical qualities. Nice work Ken. :cheesygrin:
  • [Deleted User]
    edited May 2012
    Ah yes, plenty of Baltimore Basement air involved!
    One of the things I think I need is an ultrasonic cleaner of some kind. Now I spend a lot of time individually polishing screws, bolts and other small pieces. If anyone can recommend a good approach I'd appreciate it. I clean the leads on resistors and capacitors before soldering, I don't think I'll try ultrasound on the caps, but perhaps the resistors? I've read about units that vary the sound frequency so they can be used on filled circuit boards without damaging parts. I don't know if I want to get that involved (which I easily tend to do).
    Anyone have experience in this kind of thing?
    Cheers, Ken
