Help with Tube amp speaker wiring
ok, I am having a bit of trouble here hooking up two speakers, I have got them to work but want to make sure its right.. I included a photo the switch on the top left is a phase selection switchand directly above it says channel B and then there are (2) connections directly below that are not labeled and say speakers underneath. the center row has a 16, 8, 4 ohm connection and the far right has a 16,8,4,0 and is labeled channel A.. there is also the black wire coming out of the case which I assume is to select the ohms. can anyone help my through this, thanks in advance
Hello Kitty am/fm CD player
Just use the 4 ohm taps and you will be fine. They are there to match your speaker impedance. Hook the spape to either 4,8 or 16 ohms to match your speaker, if not sure about your speaker hook it up to the 4 ohm tap. Then hook your speaker to the outputs next to them.
