Fixing the null
pentoncm
Have you guys ever experienced anything like this? It probably has a lot to do with speaker aiming and the interior of the car, and how far the speakers are down on the door panel.
Audison Bit Ten
Kenwood X595
Polk MM6501
Polk MM1240
Mtx 704x
Alpine MRX50
Kenwood X595
Polk MM6501
Polk MM1240
Mtx 704x
Alpine MRX50
Post edited by pentoncm on
400-500 hz is a woofer issue. If you have an spl meter, or an spl app on your phone, use the test tones to see which side is hotter in the 300-600 range. You will know you have this range right once your imaging gets clearer. Fundamentals and early harmonics of a lot of instruments and vocals are in this range
